Results 1 to 4 of 4
Thread: broken bolts
    Pekin, IL
    broken bolts
    Many of you may know this method but I just found it. Hope it helps.
    Extract Broken bolts from deep hole NEW easy WAY - YouTube
    Rock
    Team Junk
  2. Thanks CI STV, Garth91, XstreamVking, Baker343 thanked for this post
    Likes David - WI, sonicss33, mach351 liked this post
    Mar 2004
    Brooklyn Park, MN
    Man, I have a broken bolt in an aluminum hub for my KX450 but it is only 6MM bolt! I wonder how small of bolt this would work for? I may be looking for some small coper pipes and try this. Dang screw extractor broke off in the dang bolt too trying to get it out the first time!
    1973 Viper - sold
    1978 Viking - sold
    1995 XB02
    Alum will dissolve iron/steel out of aluminum... get it at the grocery store or drug store. https://hackaday.com/2015/08/03/diss...m-the-grocery/
  5. Thanks rock thanked for this post
    Jun 2018
    Floating around
    Everyone has some disasters with this once in a while. Ive had to go so far as to drill big, thread in larger bolt and tap the center of the bolt to size before. Of course this always happens late at night when your in a time crunch and there really isn't the option of waiting to get more tools or support and of course in the cold without heat and then you stuff a screw driver through your thumb trying to release the damn wire connector thats corroded together. Weather pack... you young fellas have no idea how good you have it now
  7. Likes rjdubiel liked this post
  1. Broken Rod Bolts
    By spirit5.6 in forum Technical Discussion
    Last Post: 09-14-2010, 05:33 AM
  2. Midsection broken bolts, what to do???
    By mxz in forum Technical Discussion
    Last Post: 04-13-2010, 01:27 AM
  3. Mercury Tech: Broken bolts
    By Will I Am in forum Technical Discussion
    Last Post: 04-03-2010, 12:29 PM
  4. broken bolts
    By 1bad67 in forum Technical Discussion
    Last Post: 07-02-2006, 09:01 PM
  5. broken bolts
    By kennyg in forum Technical Discussion
    Last Post: 06-26-2004, 09:07 PM
