Results 16 to 30 of 44
12-31-2017, 06:36 PM #16Supporting Member
- Apr 2003
- New Smyrna Beach, FL./LOTO
- 6,643
- 606
- 923
- 1698
- 7145
- 3 Post(s)
These pictures are from yesterday. Its on a 1990 24 that we owned for a couple years in the mid 90s. The current owner noticed some blistering on the outside of hull just above the running surface and I advised him not to let it go any further. The core is out, ready to be replaced and bagged with composite. Then it will have independent tanks from Doug Wright glassed in place. The balsa on a skater becomes a real problem if it is bad under the tanks and the tanks are still good. When that happens you have to dig into it from the outside. Right now the rest of this boat still looks good and thankfully it was caught early.
Unfortunately the ethanol issue along with riggers not sealing holes and people hitting submerged objects all make up and create these issues. I am not going to mention any names but there is a 2 year old boat that was over 600K and already has some serious core rot issues. The boat has never been in the water for more then 24 hours at a time and stays in a climate controlled building of its own but when it was rigged, someone didn't chase things with a resin brush and now its a mess. The water intrusion happened from running and washing the boat "all things that you would expect to be able to do".Last edited by JPEROG; 12-31-2017 at 06:46 PM.
noli liked this post
12-31-2017, 07:05 PM #17
Wow! that Eliminator sure is nice. back to our regular programming. "Sorry Noli"
12-31-2017, 07:49 PM #18
No need ^^^^
I always enjoy Joe's posts....they're from experience
NICE PAIR liked this post
12-31-2017, 07:55 PM #19
Joe, is that your 24 at DW's?
12-31-2017, 08:34 PM #20Supporting Member
- Apr 2003
- 6,643
- 606
- 923
- 1698
- 7145
- 3 Post(s)
Yes, we are doing the rest of the transformation in the next few weeks. Its finally going to get back on the water as a "Skater done Wright". Hopefully it runs decent-I have a few pretty smart guys involved.
12-31-2017, 08:39 PM #21
She's a beauty. Can't wait to see new pics I should be back at DW's before end of January. And then again around Miami Show time.
02-12-2018, 07:08 PM #22
NICE PAIR, OrangeCrush liked this post
02-12-2018, 07:14 PM #23Supporting Member
- Apr 2003
- 6,643
- 606
- 923
- 1698
- 7145
- 3 Post(s)
That get work is killer....
02-12-2018, 07:38 PM #24
Saw these this morning...Gelcoater is one of, if not the best, guy out here for gel work. Twin 400R boats.
02-12-2018, 09:24 PM #25I'd rather be competitive w/junk I built in my garage than win w/stuff I bought.
Checkmate 16' 140 Johnson
Laser 480 (?) 21' w/GT 200
24' Sonic w/twin 250 Johnsons
02-12-2018, 09:43 PM #26
To the wood construction:
I raised the 15" transom on a 30 yr old Whaler to 20". Wood was all orig and bone dry w/zero rot.
I restored a 30 yr old 16' Checkmate that I found outside, abandoned, uncovered in a corn field in Ohio. Zero rot anywhere, including its balsa core.
100% of the rotted wood Ive repaired/replaced (balsa and otherwise) Ive been able to attribute to poor construction (uncoated floor undersides, remounted seat bases, dock/beach/rock rash, unsealed repower bolts etc, etc) and user error.
Core (blasa included) is very difficult do well and IMO unless your bagging or infusing it...., its wrong.
Professional Boat Builder mag did a story about this yrs ago. Appeared on their radar screen after they were seeing multiple issues w/delamination on Grand Banks trawlers which were considered to be top quality in that market segment.
The story had pixs of 3' x 3' areas of glass peeling away from its balsa core. The core was dry.
As in, ****ty, ****ty, ****ty installation.
Bass and Walleye mag (I think) did a very well researched story comparing the wood vs no wood construction. Had input from heads of top level boat builders from both sides.
End of the day, they all agreed that "done right" they were the same. Also, all agreed, it came down to marketing.
As in, stickers on the transoms advertising "100% wood free construsction"
As a long time builder/repairer and racer of wooden boats and plastic boats w/wood bits in them, it aint the woods faultI'd rather be competitive w/junk I built in my garage than win w/stuff I bought.
02-13-2018, 08:59 AM #27
NICE PAIR thanked for this postInstigator liked this post
02-13-2018, 09:25 AM #28
An issue to proper coring w/balsa is the amount of resin penetration/saturation.
When I recorded my Vector a 100 yrs ago I estimated 2-3 gls of resin.
I used 11 and could of used more!
That was because I didn't bag it but made me wonder, @ 11 lbs per gallon of resin, how much weight did the balsa save
Another issue surfaced when I was working for Nida Core in PSL.
We had an issue w/a builder receiving an order of balsa core that was supposed to be pre-coated w/resin (can order either way) that they claimed was not.
I jumped in my truck w/a replacement order of the correct stuff.
Got there and met w/them to do the swap.
W/2 panels side by side, one pre-coated, one bare, WE COULD NOT TELL which was which!!
We were shocked.
So even bagged or infused, how much resin does it really require???
Scary.I'd rather be competitive w/junk I built in my garage than win w/stuff I bought.
02-13-2018, 10:07 AM #29
My bagged and infused viscous Tague built was the stiffest boat I’ve ever driven. It was all 3/4” nidacore with coosa transom floor and dash. It was 600lbs and I owned an 860lb ski racer before it that was no where near as strong. Beef could stand on the top of the dash and it would t creek could walk up and down the boat anywhere. 3yrs with 12” setback and 550lbs hanging on it transom never even got a tiny stress crack and I ran it in water where the bottles (soda of course) in the sponson would be broken when I got back to the ramp. The water was louder then the motor in the boat at some speeds.
Instigator thanked for this postNICE PAIR liked this post
02-20-2018, 11:04 AM #30
23' Eliminator resto-mod pics
By engineermike in forum General Boating DiscussionReplies: 136Last Post: 06-25-2018, 07:51 PM -
Contact number for Jack that builds stv boats in Jacksonville
By Hull's Racing in forum General Boating DiscussionReplies: 1Last Post: 05-22-2011, 06:00 PM -
Eliminator pics
By david martin in forum General Boating DiscussionReplies: 17Last Post: 01-18-2008, 10:02 PM -
Why Discovery doesnt have boats builds up
By Donat in forum General Boating DiscussionReplies: 13Last Post: 11-28-2004, 11:57 AM -
Who builds boats?
By C. Phillips in forum Fiberglass and Composites DiscussionReplies: 4Last Post: 08-18-2004, 02:35 AM
