Results 1 to 7 of 7
Thread: 94 Merc 200
    Aug 2004
    Manitoba
    94 Merc 200
    Hi members. I have a '94 200hp Mercury with a CLE bottom end.
    I'm trying to figure out what the next powerhead is that I can put on it. I would rather just replace it then purchase another complete motor. Also, possibly looking at putting a 225 powerhead on instead.
    Thanks for reading. Chris
    May 2014
    Livingston, Louisiana
    200 hp and down 2.5 fit with no changes. 225 pro max has rectangular exhaust ports compared to square ports on the 200 and will require also changing adaptor plate or getting ports cut in your plate. 225 3.0L won't fit.
    Nov 2004
    LEBANON OREGON
    Any 2.5 can be made to work
    Mar 2010
    houston, tx
    I might catch heck for this but for 2.5's below the 260 and not turning crazy rpm(under 9k) I like the 2.4 Bridgeport adapter plate the best especially on a heavier rig(over 1300 with driver and fuel)
    Aug 2004
    Manitoba
    The motor I have now is a 1984 2.4l block on an 18ft Hydrostream V-King. Not sure if it's an 86 or an 89.
    Florida Keys
    You'll be amazed just switching to a later (96-99) 2.5 200EFI. About the best bang for the buck around in my opinion.
    '95 STV "The Blue Goose"
    Aug 2011
    South Georgia
    Quote Originally Posted by mach351 View Post
    Fixing to try it out.
  1. merc water pressure gauge part# to match older merc gauges??
    By syclone01 in forum General Boating Discussion
    Last Post: 09-09-2016, 10:48 PM
  2. Lifeline jacket, merc manual, merc lifting ring, LU flush adapter
    By John S in forum Misc. Parts and Accessories
    Last Post: 07-13-2016, 02:21 PM
  3. Mercury Tech: 50hp 4cyl Merc vs. 70hp 3cyl Merc vs. ??? - Weight vs HP - Opinions??
    By Steve2ManyBoats in forum Technical Discussion
    Last Post: 02-22-2016, 07:25 AM
  4. Replies: 17
    Last Post: 01-30-2016, 12:35 AM
