Results 106 to 120 of 144
Thread: 225 HPDI rebuild
08-26-2019, 11:19 PM #106Member
- Dec 2007
- Clovis, CA
- 36
08-27-2019, 09:05 AM #107
Thank you sir !
And yes I am willing to do the heads for you .
I'll PM you, my shipping address etc ..
01-04-2020, 12:17 AM #108
Hello Gents
Thanks for posting the build of this engine. I'm in the process of purchasing a 250 HPDI that needs a rebuild. I have a quick question for you, do you think there is any benefit putting the 300HP head son this motor. I know they have different port timing and ECU but everything else seems to be the same. Do you think there would be much gain in doing this? I'm not racing the engine I want it stock (mostly) just liek to get the most out of it.
Cheers
Jason
Sold the old Formula 233.
Now have a 22ft Whittley Sea Legend powered by 225 Excel with Pro-V 200 covers.
01-05-2020, 10:07 AM #109
Increasing compression and tightening squash will definitely help. I’m not a Yamaha guru so I can’t answer if the 300 heads are any better/ different than your 250. If you can establish that they have lower cc or better squash, then yes
01-05-2020, 10:26 AM #110Team Member
- Jul 2004
- Connecticut
- 6,011
- 465
- 168
- 912
- 951
01-06-2020, 08:36 AM #111
Think he’s barely had time to get it broken in. I know he was thrilled with the mid range acceleration, not sure if he’s ran up top to see if gained mph.
01-13-2020, 05:50 PM #112
01-13-2020, 06:02 PM #113
01-14-2020, 01:04 AM #114
01-14-2020, 01:06 AM #115
08-05-2020, 10:59 PM #1165000 RPM
- Aug 2008
- Toronto
- 117
08-09-2020, 07:35 AM #117
Sorry, just saw this and been busy and haven’t been on as much. Unfortunately has had some mishaps. He ran into some rocks down in Venice and damaged bottom of boat. We had another injector that was on edge of tolerance. A new one was around $400. I had told him let’s find a set used and get em tested and cleaned, then pick the best balance of all and put in engine accordingly. Well low and behold he found a set for like $100 and put em in motor himself with no testing because seller told him they where good. Well you know if someone has whole set they don’t need, it’s because what’s around is toast, and mo than likely for a good reason. Well, you know the rest of the story
08-09-2020, 08:02 PM #118Screaming And Flying!
- Dec 2001
- 9,502
- 271
- 191
- 1976
BOOM/………..Dry fire.... Lean burn......K car.....dammm**** and snozzeles…...I like rich carbs......and High timming…...
08-10-2020, 05:30 AM #119
08-10-2020, 12:11 PM #120
ALWAYS have injectors tested after purchasing them unless you purchase from a REPUTABLE injector shop. I've lost count on how many "just serviced" or "flow matched" sets I've tested that aren't even good for scrap. Its too bad you had to learn this the hard way.
Blake
www.InjectorService.com
Call/Text - 204-326-0390
best place for powerhead rebuild/lower rebuild on Long Island?
By play2win in forum Technical DiscussionReplies: 2Last Post: 08-08-2011, 01:49 PM -
Mercury Tech: 3.0L S/Master Rebuild-Who's a good source for a rebuild ?????
By Liberator*21 in forum Technical DiscussionReplies: 4Last Post: 10-06-2010, 06:39 AM -
Mercury Tech: Powerhead on Mercury 125 hp/to rebuild or not to rebuild? Help! Please?
By rickyo in forum Technical DiscussionReplies: 5Last Post: 06-05-2010, 04:08 PM -
Yamaha Tech: Turn My 175 HPDI into a 200 HPDI
By BroCo in forum Technical DiscussionReplies: 0Last Post: 07-27-2009, 01:53 PM -
3.3 hpdi hop-ups
By Red in forum Four Stroke and Direct Injected Two Stroke EnginesReplies: 2Last Post: 07-30-2005, 04:32 PM
