Results 1 to 5 of 5
    Jul 2018
    Escondido, Ca
    Steering Wheel Quick Disconnect
    I recently purchased a used Progression 24LD and have discovered that with the seat in the optimal position for driving comfort it is a tight squeeze to get in and out between the seat and steering wheel. Is anyone aware of a company that makes a steering wheel quick disconnect that will bolt to a 3/4" taper shaft? Everything I can find online is for a standard 3/4" shaft and is weld on, I don't want to weld to my SeaStar hydraulic helm.
    Picture below is from the previous owner, I purchased it without power and will be putting a new Yamaha on it.
    Thanks in advance,
    -Garrison
    Jul 2004
    houston,tx
    ive used them on skaters with poker run type seats
    lathem marine makes them for boat fitting the 3 and 6 bolt pattern wheels
    not cheap but nice
    Nov 2003
    Simi Valley, SoCal
    Quote Originally Posted by yzfaster41 View Post
    Thanks in advance,
    -Garrison
    There is a ton of options on Jegs but I don't see any for a taper. There are some that go between the existing hub and the wheel but that would set the wheel back a bit. You could probably have a center made for one of the hex type. It's a pretty simple part and the other option is to have a tapered insert made and pressed/welded into one of the race car type. That looks like what Latham did and made the hex type insert out of stainless.
    96 Cougar 23 MTR twin 300XS's. 100 something
    98 Laveycraft Sebring 20.2 Tunnel 280 90 something SOLD
    85 Baker RST 220 Laser SOLD
    Jul 2018
    Escondido, Ca
    Thanks for the info, I'll give Latham a call
    Jan 2007
    I installed a NRG Thin Quick Release onto a 3/4" tapered hub I found on ebay. Search on "Marine Boat Steering Wheel Hub Adapter Keyed for MOMO NARDI NRG SPARCO OMP" It did require a bit of machining on the outer edge of the hub to let the NRG piece fit around it, though.
    2001 Spectre 30 w/twin 300X - sold
    2008 Velocity 390SS w/twin staggered 525efi - sold
    2003 Sonic 31SS w/twin 496HO - sold
    1988 Baja Sunsport 196 w/500HP SBC and 125 shot nitrous - sold
  1. Quick Disconnect
    By pbxcomm in forum Technical Discussion
    Last Post: 01-19-2018, 02:39 PM
  2. Sea Star quick disconnect steering wheel
    By scott reierson in forum Electronics, Audio Systems, and Wiring
    Last Post: 02-22-2011, 12:52 PM
