Results 1 to 15 of 21
Thread: What is this?? Pulled Powerhead
07-12-2019, 06:44 PM #15000 RPM
- Mar 2017
- Miami, FL
- 358
- 10
- 47
Pulled a powerhead and this stayed on the driveshaft. What is it?
07-12-2019, 08:19 PM #2
That is part of your blown out bottom crank seal. I blew several on my 2.5s over the years, probably from lean-sneezes.
"Confidence" is that wonderful feeling you had right before you fully understood your true situation.- Unknown
I don’t know what effect these men will have upon the enemy, but, by God, they terrify me.- Duke of Wellington“I am not afraid of an Army of lions lead by a sheep; I am afraid of sheep lead by a lion.” – Alexander the Great
Whoever said the pen is mightier than the sword obviously never encountered automatic weapons.-Douglas MacArthur
Allison GSE 300XS
07-12-2019, 08:34 PM #35000 RPM
- Mar 2017
- Miami, FL
- 358
- 10
- 47
I did more research. Looks like the seal carrier. Designed to keep the splines on the driveshaft clean I think. Not really part of the seal it seems
07-13-2019, 06:54 AM #4Supporting Vendor
- Sep 2006
- Key Largo, Fl
- 3,274
- 215
- 30
- 585
Nothing to do with crankcase sealing,just a seal(o ring)carrier that taps into the bottom of the crank to keep grease on the splines and water out of them,clean it and the crank,apply your favorite glue,and tap it back...Chris
Dave Strong, tux974 liked this post
07-13-2019, 06:59 AM #5Supporting Vendor
- 11,838
- 163
- 11
- 795
Technical term IS seal carrier about half the motors I build them half not they tap onto the bottom of the crankshaft , my guess is to protect the splines from salt or brackish water I coat the hell out of the upper drive shaft spline with a good grade of anti seize before assembly, works great
JayJay @ JSRE
07-13-2019, 07:02 AM #65000 RPM
- Mar 2017
- Miami, FL
- 358
- 10
- 47
Thank you Chris. I’ll do exactly that
07-13-2019, 07:49 AM #7Supporting Vendor
- Sep 2006
- Key Largo, Fl
- 3,274
- 215
- 30
- 585
Yes,be sure you do,without it in place the grease will quickly be slung out and the dry splines will wear and rust away in salt water...all 60 degree mercs,2.0,2.4,and 2.5's 1976 on came with them,and although sometimes they fall out and get left out,they need to be in place.Do not put a big gob of grease on top of the driveshaft when putting the gearcase back on,as this can hydraulic the seal back out when the grease is compressed... with no place to go,it pops the seal carrier out,Chris
07-13-2019, 08:22 AM #8
All the Mercs I deal with are freshwater bass motors. I've never seen one...
Josh Peterson
07-13-2019, 08:38 AM #9Supporting Vendor
- Sep 2006
- Key Largo, Fl
- 3,274
- 215
- 30
- 585
07-13-2019, 08:54 AM #10Supporting Vendor
- 11,838
- 163
- 11
- 795
Like I said half motors have em the other have don’t and like nitro said I build mostly fresh water pieces , the anti seize is what I have always used , JMO ...If you wanna replace jut remove and tap back in bottom of crankshaft !! No biggie!
JayJay @ JSRE
07-13-2019, 09:15 AM #11Supporting Vendor
- Sep 2006
- Key Largo, Fl
- 3,274
- 215
- 30
- 585
I suppose you might get away with not having it in place in a limited use fresh water situation,where i'm at the splines would be gone in a year of fishing,or so frozen the gearcase wouldn't come off...all the cranks came with them from the factory,if they aren't there they have simply been left out,fact,not opinion...
07-13-2019, 09:53 AM #12Supporting Vendor
- 11,838
- 163
- 11
- 795
Thanks Chris for that info I will take it under consideration . I’m always willing to learn and improve my work . Been building these hi per motors for 25 years but always willing to consider others ways of doing things
Thanks,
JayLast edited by Jay Smith; 07-13-2019 at 10:01 AM.
Jay @ JSRE
07-13-2019, 10:03 AM #13Supporting Vendor
- Sep 2006
- Key Largo, Fl
- 3,274
- 215
- 30
- 585
Thanks Jay,and you're welcome...salt water motors really need em,Chris
07-13-2019, 04:28 PM #14The Historic Photo Master
- Jan 2004
- Florida
- 37,827
- 64
- 1667
- 337
- 19201
- 3 Post(s)
07-13-2019, 05:23 PM #156000 RPM
- Jul 2011
- Gloucester, VA
- 1,311
- 19
- 90
- 180
- 342
Yes they do! We get very very few FW motors in out shop but when we do oh my is it a treat. Lol
I always love the freshwater guys in class that say, "make sure you lock tight that bolt" and the saltwater guys respond with "lock tight? You better anti-sieze it so you can get it out".Last edited by RSWORDS; 07-13-2019 at 06:34 PM.
rochelle howell, Whaaaaat liked this post
Getting pulled over
By wired247 in forum The Scream And Fly LoungeReplies: 21Last Post: 04-08-2015, 08:27 PM -
How To Check Compression on Pulled Powerhead
By computertamer in forum Technical DiscussionReplies: 18Last Post: 09-10-2014, 09:06 PM -
What WILL get You Pulled Over... AND What Will Get You Out of a Ticket. :)
By Fish in forum The Scream And Fly LoungeReplies: 10Last Post: 06-13-2011, 07:26 PM -
Pulled my motor
By Meatbasher in forum Technical DiscussionReplies: 0Last Post: 11-21-2010, 07:41 PM -
You know why I pulled you over sir?
By Capt.Insane-o in forum General Boating DiscussionReplies: 25Last Post: 07-03-2007, 09:51 AM
