Results 1 to 6 of 6
06-04-2023, 09:02 AM #1Junior Member
- Aug 2008
- Jacksonville
- 12
Mercury ProMax 225 Bushing / Sleeve - Need Help Identifying Placement
Hello,
I installed new reeds and thought I adequately documented what goes where as I disassemble but apparently not good enough. Can anyone help with where this bushing is supposed to go? I’m not sure whether to refer to it as a bushing or a sleeve and can’t find a schematic showing it.
Thanks for any help!
Haydon
06-04-2023, 10:19 AM #2
Remove VST mounting bolts, may have fallen out of one of the rubber bushings.
jaxflats thanked for this post
06-04-2023, 10:41 AM #3Screaming And Flying!
- 14,753
- 381
- 1305
- 5602
- 11033
Spacer between switch boxes?
06-04-2023, 11:36 AM #4Junior Member
- Aug 2008
- Jacksonville
- 12
Thanks, I think it did go with the VST mounting. I really appreciate it.
06-04-2023, 11:48 AM #5Junior Member
- Aug 2008
- Jacksonville
- 12
One other question, what is the name/type of part of the straight black plastic part with the Phillips Head screw in the bottom right of the photo of the outboard? Thanks Again
06-04-2023, 01:14 PM #65000 RPM
- Mar 2023
- SW Florida
- 479
- 28
- 76
jax. open the second thread. hit edit. hit delete 3 diff places and it will be gone.
Oil Pump Drive Bushing for 225 Promax
By ssntmd8r in forum Parts WantedReplies: 0Last Post: 05-27-2018, 04:04 PM -
I need help identifying the lower on this 300 promax
By BigKiddd in forum Technical DiscussionReplies: 4Last Post: 07-02-2015, 05:27 AM -
What sleeve is this? Suppose to be a 225 promax.
By WaterBoy in forum Technical DiscussionReplies: 9Last Post: 08-24-2014, 10:14 PM -
Mercury Tech: 2.5 Mercury EGT probe placement
By jhelmly in forum Technical DiscussionReplies: 13Last Post: 06-04-2011, 09:11 PM -
Mercury Tech: 225 ProMax Sleeve question
By TheRickster in forum Technical DiscussionReplies: 2Last Post: 07-24-2008, 07:12 PM
