Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 45
    PARADISE /Naples
    DSRA/ODBA Lake Racer
    Anyone one know what the top competitors in Lake Racer class are using for motor option these days?
    This class has way more motor options and the weight changes with your choice, just wondering what the top competitors are using today?
    I have a Mod Production motor that is sweet thinking about going that route.
    Thanks
    Sep 2007
    Pensacola FL
    Super gas 200 , prostock 200, bone stock drag motor & the stock 280 have all 4 won in Dsra this yr. stock 260 & stock 280 has won this yr in Odba.
  3. Likes Michael J Giesler liked this post
    PARADISE /Naples
    Thanks Taylor, so the lighter weights have been the winning combo's, I never ran the short track, good to know.
    Mar 2002
    Rockford, MI
    Don't run Modified Pro rules...You'll be left at the start line...Trust me, 800' is not for that weight, we just got schooled.
    Thanks
    G
    "The Flying Clamato"
    ...This ain't no Party, This ain't no Disco, this ain't no foolin around..."Talking Heads - Life During Wartime"
    The G-Train has left the station.
    PARADISE /Naples
    Did you run your 1/4 mile set up ? you always made plenty of power in the past.?
    Mar 2002
    Rockford, MI
    Jim, we changed to a 20p prop, and tried moving weight around, but those guys have the combo down, and they are very strong.
    I was told many times before we went down there that the combo we were going to run would not compete...they were right.
    Regardless, we had a great time, and saw a lot of faces from the past, and met new racers...everyone was extremely friendly.
    Later
    G
  8. Likes AZMIDLYF, tunnelmike, bullwhipjkg liked this post
    Aug 2011
    South Georgia
    What engine combo were you running.weight.
    PARADISE /Naples
    !700 lb Mod Production air horn
    1715 SVS Mod Pro
    260 26 cc heads 1550
    Pro Stock legal 32 cc heads 1400lb and the DSRA Guys know how to make them SING, nothing like getting beat by a 200
    Stock 280 37cc heads with drag electronics 1550 lb.
    Stock 280 drag electronics using tight whatever you want heads 1675 lb.
    Super Gas 200 1500 lb.
    The list goes on and on have to check out web site going to Diner
    Many Many choices
    Any motor can race check rule book Great Class.
    Mar 2002
    Rockford, MI
    We ran Modified Production rules, SVS Drag, 1715 lbs. STV River Rocket
    Aug 2011
    South Georgia
    We run stock drag 37cc svs 1565lb.2 nd yesterday.i believe Winner Seth runs 280 16 amp package.1550lb very close.
    PARADISE /Naples
    So the 26cc 260 is the same weight 1550
    What kind of rpms you turning ?
    I have a stock 280 or a 260
    I wonder how much better the 280 breaths at top end?
    Never tried to run 37cc heads, do they turn higher rpms than a higher compression motor.?
  14. #12
    shreveport,la
    I’d run the 280 if you have one. 260 might have a few more rpm on top but it’s not enough to worry about. A well setup stock 280 or 260 and you’ll be in the mix. As a rules committee we may need to revisit the Mod Prod weights this off season
    Erik Kiser
  15. #13
    Mar 2002
    Rockford, MI
    Quote Originally Posted by patchesII View Post
    Thank You Erik...I talked a little with Mike Clemmons, and he thought the rules may need a little cleaning up also.
  16. #14
    Mar 2002
    Rockford, MI
    Quote Originally Posted by timmc6 View Post
    This is part of the problem. I would have thought you would have to run 1615 lbs, per the rule book. Not trying to say you did anything wrong, but so many combos it gets confusing.
    This is just part of the class rules for Mercs, as you know.
  17. #15
    Aug 2011
    South Georgia
    Rule book is confusing for shure.we work with Mike regularly.to clarify everything.
  1. ODBA lake racer class
    By ahead of u in forum General Boating Discussion
    Last Post: 10-11-2016, 04:53 PM
  2. Odba Lake Racer
    By JAC in forum Racer's Hangout
    Last Post: 03-30-2006, 06:37 AM
  3. Odba S/S Rules And Lake Racer
    By kim cleckler in forum General Boating Discussion
    Last Post: 01-09-2003, 11:31 PM
  4. Odba Lake Racer Class
    By PETE PALETTA in forum General Boating Discussion
    Last Post: 09-15-2001, 08:46 PM
