Results 1 to 1 of 1
Thread: New low cost ECU alternative!
07-21-2006, 08:51 AM #1
The Brucato Advanced Control Unit (ACU) is designed to be a replacement for your stock ECU on select Mercury outboards.
At only $1025, the ACU costs hundreds less than a new Mercury ECU.
The ACU will be programmed with a fuel curve for your engine and includes a mounting bracket for direct replacement. Nothing else to buy!
Curves and mounting brackets are available for these applications and many more:
150, 175, 200 HP EFI; 150, 200, 225 ProMax; 220 Laser, 2.5 Drag, 2.4 EFI,
F1 Motor, 260 EFI We can supply custom fuel curves and rev limits.
You can read more about the ACU at http://brucatosvs.com/acu.html
or you can call me @ 919-718-0249Last edited by Tony Brucato; 06-10-2010 at 07:23 AM.
