Results 1 to 12 of 12
Thread: 225 Optimax Pro XS performance.
11-24-2024, 09:19 AM #1
Junior Member
- Nov 2024
- Ashland KY
- 11
Is their any way to get more power out of a 225 Pro XS Optimax other than bolting a 250 or 300XS powerhead on to it?
11-24-2024, 10:10 AM #2
Team Member
- Lake Coochiching, Ontario
- 8,457
- 43
- 403
- 667
- 2124
- 6 Post(s)
Usually set up, engine height, setback, prop, is step one in the quest for speed. For me step two was buying a faster hull for the same motor. I picked up 10 mph with each step.
What do you have now ?
11-24-2024, 10:14 AM #3
Junior Member
- Nov 2024
- Ashland KY
- 11
11-24-2024, 02:29 PM #4
Team Member
- 8,457
- 43
- 403
- 667
- 2124
- 6 Post(s)
High 60's doesn't seem like a lot with 225HP, but I don't know much about bass boats. I asked Mr Google about your boat and found some old posts on BBC that suggest 71-72 should be possible with 225 HP.
https://www.bbcboards.net/showthread.php?t=419439
https://www.bbcboards.net/showthread.php?t=422170
Have you tried going higher with the engine? Does the boat carry the bow well, or do you need a lot of trim?
11-24-2024, 02:37 PM #5
Junior Member
- Nov 2024
- Ashland KY
- 11
I have played with the jack plate settings quite a bit. I have tried a 24p Tempest, 25p Tempest, 25p Fury, 24p Ronnie Gilbert worked Fury, 23p Mark Croxton Razor 3 and a 23p Solas Scorpion. The 25 Tempest works the best out of all of them, I get my best speed by trimming all the way up then bumping it down some. It does need the bow lift of the Tempest, both of the Fury props I tried didn't have enough bow lift and ran poorly.
11-24-2024, 05:53 PM #6
Team Member
- 8,457
- 43
- 403
- 667
- 2124
- 6 Post(s)
Maybe bow lift is the key. If I were in your shoes, I would try to get to 72 +/- with the stock motor before chasing HP.
11-24-2024, 07:09 PM #7
Junior Member
- Nov 2024
- Ashland KY
- 11
09-25-2025, 12:21 PM #8
5000 RPM
- Mar 2004
- vonore tn.
- 250
- 33
Triton is a good all around boat, but not the best highspeed bass boat. If you want more speed, take out all troll batt,s. & troller off front. Then borrow a 27" pitch prop. It should turn that fine. To go from a 225 to a 250, you need to run the bigger & more press. injectors from the 250. You,re better off changing the p'head or complete motor.
09-25-2025, 12:46 PM #9
Junior Member
- Nov 2024
- Ashland KY
- 11
09-26-2025, 06:19 AM #10
5000 RPM
- Dec 2009
- middle tennessee
- 368
- 124
- 66
- 284
- 290
10-09-2025, 03:44 PM #11
5000 RPM
- Mar 2004
- vonore tn.
- 250
- 33
DUDE I thought you might just want to find, how fast your boat MIGHT be.
10-10-2025, 09:31 AM #12
5000 RPM
- Dec 2017
- Okeechobee FL
- 268
- 50
- 31
- 329
Mercury Tech: 300 xs optimax engines, performance tips
By alohr in forum Technical DiscussionReplies: 1Last Post: 08-23-2011, 08:19 PM -
Mercury Tech: 225 Optimax Performance
By fishingken in forum Technical DiscussionReplies: 1Last Post: 04-25-2011, 05:08 PM -
Performance Mods For Optimax 2.5xs
By mwarjone in forum Technical DiscussionReplies: 4Last Post: 05-22-2005, 05:01 PM
