Results 1 to 7 of 7
    May 2001
    Maine
    Anyone tried a 4 blade ProMax Prop on a STV?
    Just curious as to the prop/cons.
    Feb 2010
    wisconsin
    probably have a bit more stern lift that what your used to depending on what gearcase your using on it.
    May 2001
    Maine
    I was thinking it may help get over the hump with the heavy 3.0L motors but then you would be limited in height do to the thru hub exhaust.
    Feb 2010
    wisconsin
    Quote Originally Posted by 4Speed View Post
    That could vary a little but should stay close .. it will physically lift the stern higher so you might not have to go as high up on the jackplate per say . “ bigger water ski” with the tube on there .
    Aug 2013
    Oshkosh, WI
    Agree with wicheckmate, the ride is much better with a Pro Max versus a solid hub as well, much smoother thru waves
    My 28 carries the boat very well with weight. Minimal slip acts much bigger than it is still runs 110+ with a passenger. I’ve also towed a couple heavier boats on plane with passengers in both.
    May 2001
    Maine
    Just wondering if there are any additional experiences over the years with the Promax prop on a STV Euro.
  1. comparable 4 blade ss prop to a BRP rogue 4 blade?
    By zwalls in forum Props, Setup, and Rigging
    Last Post: 09-03-2011, 09:49 AM
  2. New 6 blade CNC, stager blade, prop
    By appsyscons in forum Props, Setup, and Rigging
    Last Post: 07-09-2008, 10:08 AM
  3. 3 blade laser II prop or 4 blade offshore?
    By Air Dog in forum Props, Setup, and Rigging
    Last Post: 04-05-2006, 11:56 AM
