Results 1 to 4 of 4
    May 2024
    Carmel California
    Central California Mercury Mechanic Recommendations Anyone?
    Hiya,
    I'm a new member here looking for some advice. I live in Carmel in the Monterey Bay area of California's Central Coast. Can anyone reccomend a top notch Mercury outboard mechanic near me? I recently purchased a 1996 Barefoot Sanger with a Mercury 200 XRI. It is the original motor that came on the boat but had the powerhead replaced early this past summer. I have not yet driven the boat or started the motor. The boat is in pristine condition with a little over 400 hours on it. I drove to Mississippi and back to purchase it. Car troubles in Louisiana prevented me from driving it if I wanted to make it home by Thanksgiving. I have no reason to doubt the PO when he told me that it runs great and he had been barefooting behind it all summer. I have purchased the service manual from Mercury and will be doing the maintenance myself at some point but wanted it to be seen, serviced and tested on the water by a seasoned expert before I even change any fluids. I have been going through the boat and cherrying it out and replacing any little things it needs. I completely dolled out behind the rear seat, replaced sump pump and hoses, installed a new thru-hull discharge, built and installed a battery switch panel etc. Eventually I will bring it to Scott Pellaton at Sanger Boats in Fresno to fix some minor scratches in the bottom hull, repair a couple of screw holes, fill the pitot holes from the mechanical speedos I removed and buff and polish the underside while it is up on slings, then buff and polish the top side and dash. But I really need a Merc outboard wizard near me that I can trust. Help me out guys/gals. Thanks in advance.
    check your PM's
    Jan 2020
    Pittsburg, Ca
    If you cannot find one within your area send me a PM...I am in the bay area, so a little drive for you but I am sure I can help you out.
    1990 Collins Mirage - 15" 260
    25 hp Merc with dry side pipe
  4. Likes sonicss33, RADER, Trevor Sawyer liked this post
    Jul 2002
    Highly Highly Recommend Henry Abbadie at Performance Marine Specialties in Oakley Ca.
    Thanks
    Tony Cafiero
  1. Replies: 7
    Last Post: 05-11-2018, 04:18 PM
  2. Any Hi Perf Merc mechanic recommendations near Charlotte NC?
    By redpickle in forum Technical Discussion
    Last Post: 08-07-2012, 07:53 PM
  3. Long weekend getaway in central FL recommendations.
    By jtaj77 in forum General Boating Discussion
    Last Post: 08-11-2010, 08:24 AM
  4. Central Florida OMC Mechanic...
    By kimswang in forum Technical Discussion
    Last Post: 10-10-2008, 06:02 PM
  5. Mechanic needed in Central Fla area.
    By ebuck in forum Technical Discussion
    Last Post: 09-14-2005, 04:44 PM
