Results 1 to 7 of 7
    Aug 2014
    Houston
    1996 Johnson 225 Venom bottom starboard carb leaking badly out big top hole?
    About a year ago my trailer axle gave out on the way home. Well, I finally blasted and redid the whole trailer new axles and everything else, so it has been a while sense I ran it. I only run ethanol free because I am tired of all the problems that come with the E gas. Anyway, when I started it up today gas was pouring out of the big hole at the top left of the bottom starboard carb. It might have been leaking out the little copper hole at the bottom center in the first picture, but it was hard to tell from the amount of gas coming from the top hole. is this just a stuck float or a bigger problem? Hopefully not a bigger problem because I just blew the budget on the trailer.
    Attached Thumbnails Attached Thumbnails PSX_20241207_160020.jpg   PSX_20241207_155927.jpg
    12 Post(s)
    Stuck float.
    pc of cake to fix.
    Checkmate 16' 140 Johnson
    Laser 480 (?) 21' w/GT 200
    24' Sonic w/twin 250 Johnsons
    Aug 2014
    Houston
    Perfect, I ordered A Carb kit for it figured if I had to take it off, I would rebuild it. Thanks for the quick response.
    May 2001
    Hickory NC
    5 Post(s)
    Get rid of those aftermarket carb kits and install OEM
  5. Likes 108 liked this post
    12 Post(s)
    I had one do that on one of the twins on my Convincor.
    Appeared to be a tiny sliver of rubber off the inside of a fuel line, from a connection somewhere!
    Could barely see it, wedged between needle and seat!
    Cudjoe Key FL
    Was probably easier to see 20 years ago. Getting old has its disadvantages.
  8. Likes Instigator liked this post
    12 Post(s)
    Not even funny!
    My $2 readers do me just fine ��
    Quote Originally Posted by sonicss33 View Post
  1. parting out 1996 johnson 200 venom
    By anthony714 in forum Outboard Engines
    Last Post: 04-27-2021, 12:49 AM
  2. 1996 johnson venom 225 started knocking
    By Jewn.beef in forum Technical Discussion
    Last Post: 08-05-2013, 09:29 AM
  3. OMC Tech: 1996 Johnson V4 90hp - starboard side overheating?
    By fishnsane in forum Technical Discussion
    Last Post: 05-16-2012, 07:14 AM
  4. 1996 Johnson 225 Venom compression question
    By stratosman201 in forum Technical Discussion
    Last Post: 05-27-2008, 05:51 PM
  5. Lightning gearcase on 1996 Johnson 200 venom
    By evernole in forum Technical Discussion
    Last Post: 06-16-2006, 06:13 AM
