Results 1 to 14 of 14
Thread: Land & Sea Jacking Plate
03-22-2024, 02:59 AM #1
New Member
- Apr 2010
- New Zealand
I know I'm going to get laughed at however its worth asking the question - what are the chances that I can get replacement nolathane slide runners for my L&S Jack Plate? the original part number from L&S as per the attached photo was #609-600.
Did anyone ever find replacement runners from another supplier maybe?
Photo of my boat for attention
03-22-2024, 05:23 AM #2
7000 RPM
- Jun 2001
- Crosslake, MN
- 2,102
- 43
- 84
- 650
- 600
- 3 Post(s)
Side question - are they no longer around ? They were a big name 20-25 years ago.
MDS
03-22-2024, 06:42 AM #3
5000 RPM
- Dec 2008
- Coldspring, TX
- 146
- 14
- 35
Those look similar to the Atlas jack plate design. I would have no idea if the slides for the Atlas would work but maybe a starting point?
03-22-2024, 06:58 AM #4
David - WI liked this post
03-22-2024, 07:13 AM #5
8000 RPM
- Jun 2004
- long island
- 3,721
- 1419
- 1071
- 5854
- 11827
Maybe source the material from Grainger or plastic company and have machined?
03-22-2024, 07:30 AM #6
03-22-2024, 10:13 AM #7
Cuda,
I highly doubt that the link you posted has any relation to the Land and Sea of yesteryear, it looks to be a drop ship company.
Not the engineering/production company that brought many popular items such as the dual action foot throttle and stern drive jack as well as outboard dyno's
Paul V.
1987 Hydrostream Viper - 1973 V4 Evinrude 135 Crossflow "Shiny Motor"
03-22-2024, 12:17 PM #8
Land & sea no longer exists
"Thank you for visiting DYNOmite Dynamometer/Land and Sea
In March 2022 we announced the suspension of the former Land and Sea Dynamometer Company operations. "
is gone
03-23-2024, 07:51 PM #9
7000 RPM
- Central Florida
- 2,667
- 9
- 41
- 35
- 251
I don't think you will find anything unless someone has an original set on the shelf they no longer need. I recall when L&S got out of the marine business a few guys posted they bought up the few spare slides they had.
What you could do is mold new using Moglice https://moglice.com/ or similar compound. That is what I plan to do if mine ever fail. Moglice is an epoxy matrix with molybdenum, graphite, teflon, etc in various liquid and putty forms. Normally used to rebuild machine tools. Lots of examples on the internet and used to be a bunch of homebrew recipes. You would have to jig the two halves into position with mold releases, masking, wax or putty dams and then inject the liquid. Not easy but the only way I can think of if you really need or just want to save an old L&S plate.
loop liked this post
03-23-2024, 10:23 PM #10
I haven't seen them in person, but how hard could these possibly be to make... they probably cost L&S about $1 at the time... not Space Shuttle parts.
03-24-2024, 08:09 AM #11
they're what i'd call decpetively simple.
Machining them from bar stock or tubing wouldnt be impossible but a PITA and since they aren't a high demand item most machine shops would have to charge more than the jackplate is worth. Ive looked at them and haven't figured an easy way to make them (manually) From what i remember they're extruded UHMW which probably cost them pennies per foot to manufacture once they buillt the extrusion die. they probably threw away bundles of the extrusions when they stopped making the jackplates
All that being said,when i saw this post yesterday I realized that these coudl probably be 3D printed pretty easily and inexpensively. Might take a few tries to get it right but UHMW filament is available.
Then I saw Barry Strawn's post about the pourable Moglice. Either make a mold or just pour in place. I think this is by far the best solution.limited skills
David - WI thanked for this post
03-24-2024, 03:08 PM #12
"Deceptively simple" is what usually trips me up!
JBS liked this post
03-26-2024, 06:45 AM #13
5000 RPM
- May 2019
- Georgia
- 332
- 104
- 61
- 459
- 306
- 3 Post(s)
UHMW machines very nicely, with sharp cutting tools.
03-26-2024, 09:55 AM #14
yes it does machine very easily. The shape is just awkward for machining. Not impossible
limited skills
By Dirty 50 in forum Technical DiscussionReplies: 5Last Post: 11-18-2018, 03:14 PM -
Allison jacking plate
By chevrolet 55 in forum Parts WantedReplies: 0Last Post: 01-09-2018, 09:22 AM -
3 or 4 inch jacking plate?
By wettek in forum Props, Setup, and RiggingReplies: 0Last Post: 02-10-2014, 05:38 AM -
Problems with hyd. jacking plate
By jcwhite in forum Technical DiscussionReplies: 6Last Post: 08-03-2010, 03:25 PM -
Jacking plate or not
By power of one in forum Props, Setup, and RiggingReplies: 4Last Post: 05-18-2009, 06:28 AM
