Page 7 of 8 FirstFirst 1 2 3 4 5 6 7 8 LastLast
Results 91 to 105 of 108
  1. #91
    Aug 2021
    South Louisiana
    The layer in question can be cut/scored with a small hooked pick with no problem. I'm pretty sure I could cut it with a utility knife too.
    1986 Hydrostream comp Vector with factory center steer (full deck-off project in progress), working on a 2.5 Merc
    2018 Xpress H22Bay - Yammie F150
    1436 Tracker - '89 Mercury 25hp tiller (under the knife)
  2. #92
    Jun 2018
    Floating around
    My vking had a pink foam core strip on the under side of the deck. Looks similar. Of course maybe someone else has redone it before and used some foam
  3. Thanks JoshP1 thanked for this post
    Likes JoshP1 liked this post
  4. #93
    Aug 2021
    South Louisiana
    Just a wild thought. From what I hear, the Vector and Viking/Vking bottoms are the same except for the pad an lift strikes. Has anyone tried cutting out the inner lift strikes on a Vector with a flat pad? Am I out of my mind or does this make since? Thought process behind it is this. The Vectors run like somebody threw a bobcat in a sack then tied it to the tail of a horse. The Viking/Vkings run like riding a couch. Can I, essentially, have a 17' Viking/Vking by doing this? I already plan on flattening the pad on my Vector. Maybe I'm just losing my mind after years of tactical self induced abuse.
  5. #94
    Jun 2018
    Floating around
    Its totally doable although a heaping ton of work to do nicely. Vectors are better drag hulls and vkings are easier to drive speed hulls, generally speaking. Set up is everything. Some awfully fast vectors out there. Owners who love them. That said its your boat and your build do what you feel is best.
  6. Thanks JoshP1 thanked for this post
  7. #95
    Jan 2009
    Lafitte, Louisiana/ Beaumont, Texas
    If I remember right the hull was reshaped on the vking when they built it. Its different even though it looks similiar
    Modded Hydrostream Vking
    Hydrostream Vking
    Hydrostream Viper
    Sold, Hydrostream Vector, Allison xb2002
  8. Thanks JoshP1 thanked for this post
  9. #96
    Aug 2021
    South Louisiana
    D,
    Earlier in this thread I spoke about a bubble in the deck to resemble the newer Venom in place of the windshield. From what I can see in your avatar and signature pics, I probably found some pics of your build on Google. I remember seeing the boat in a YouTube video for the Hydrostream Hellions and fell in love with the deck bubble instead of a windshield. I have a pretty long way to go before I start modifying the deck of my boat, just thought I'd through it out there.
  10. Likes Deznuts3570 liked this post
  11. #97
    Jan 2009
    That's it for sure. There's a thread on here that showed some pics of it.
    Hydrostream Vking
    Hydrostream Viper
  12. #98
    On the strip of odd material, in the 80's they were experimenting with a spray able type of soft durometer core. I used it in one of my early 80's flats boats bullds and it was not very impressive. This may be some of that material. The idea was that as the fiberglass flexed from impacts it would act as a shock absorber since it was not hard.
  13. Thanks JoshP1 thanked for this post
  14. #99
    Aug 2021
    South Louisiana
    D, here's the pics I got off Google.Click image for larger version.
ID:	526231Click image for larger version.
ID:	526232Click image for larger version.
  15. #100
    Jan 2009
    That's it buddy. A bunch of good people helped along the way and I'll be forever grateful for it. It's been a great learning curve and I can honestly say, I met a dude that became a great friend off this site. Still today, it all happened here! Tons of great knowledge and tons of great people. Once your done man, it becomes a blast!
    Hydrostream Vking
    Hydrostream Viper
  16. Thanks JoshP1 thanked for this post
    Likes JoshP1, LakeFever liked this post
  17. #101
    Aug 2021
    South Louisiana
    X, if that's it, it looks like my whole bottom running surfaces have it. It sands really easy so I'm thinking of leaving it and laying up over it. I'll still sand everything like I should to get a mechanical and chemical bond with the glass.
  18. #102
    I would do an adhesion test. Clean and prep, then lay up a small square on the surface. Let it cure and try to remove it. The material may be good, or may cause de-lamination and you will have to remove it.
  19. Thanks JoshP1 thanked for this post
  20. #103
    Jun 2018
    Floating around
    Cant beat starting fresh. Remove the guesses and unknowns. Thats how i see it
  21. Thanks JoshP1 thanked for this post
  22. #104
    Aug 2021
    South Louisiana
    Lake and X, after more thought, I've decided to remove all of it. I can't see doing all this work and leaving something I'm not set on in the boat. It's just not worth it to me.
  23. Likes XstreamVking, LakeFever, BrononC liked this post
  24. #105
    Aug 2021
    South Louisiana
    I'm not dead yet! We had some financial issues and I had to take a break from working on my boat. I had to make all the overtime I could get, leaving me with no time to work on it. I had a line on a "FF" 200 for CHEAP, but my buddy sold it before I could get home. Back to the grind this weekend I guess. I have to hang up some plastic sheeting around the carport so the dust doesn't keep going everywhere. The plan is to use the two box fans I have with one blowing in and the other blowing out after pulling the inside air through a large A/C filter. Not sure it'll work out like I plan, but it's worth a shot. I'm not ready to paint or gelcoat, I'm not even finished prepping the inside to lay new glass yet.
  1. 2006 hydrostream vector comp hull
    By 265mercman in forum Hulls up to 20'
    Last Post: 12-26-2014, 10:18 AM
  2. Comp vector
    By levi ledet in forum Hulls up to 20'
    Last Post: 04-04-2014, 01:04 PM
  3. hydrostream comp vector
    By PowerCat_15X in forum General Boating Discussion
    Last Post: 07-30-2010, 07:04 AM
