Results 1 to 15 of 25
Thread: Foam core from HomeDepot
06-03-2022, 11:13 AM #1
06-03-2022, 11:18 AM #2
06-03-2022, 12:06 PM #3
It is a very low density foam, would be suitable for insulation foam but not structural. Any resin system other than epoxy will eat it as well.
rgsauger thanked for this post
06-03-2022, 01:53 PM #4
8000 RPM
- Jun 2004
- long island
- 3,720
- 1416
- 1071
- 5828
- 11827
A friend has used the tan insulation board
generally has a black plastic face - that you have to-peel off
you might get it unfaced too
anyway- I’m under the impression that it’s a urethane foam
it takes vinylester resin well
hes used it for gussets and such
i wouldn’t make anything structural out of it
im sure it would be fine for console
maybe the resident glass guys could give a better optionLast edited by doug7488; 06-03-2022 at 01:57 PM.
06-03-2022, 01:57 PM #5
nice Doug , good to know!
06-03-2022, 01:57 PM #6
The console will not carry any kind of load, I just don't want it flexing when I hit the waves, thus this foam's low density is perfect for the console
My other two concerns are ..
1. Will it hold up to the temps of epoxy resin when it hits its maximum thermal temps
2. holding power between two foam parts
here's a pic of epoxy resin with fast hardeners with no visible deformities due to high temps of epoxy resin curing
06-03-2022, 01:59 PM #7
Instigator liked this post
06-03-2022, 02:18 PM #8
please note in above pic, no deformities (the foam did not melt from the heat of epoxy curing)
and the cured resin held the two parts pretty good, I could not pull them apart
06-04-2022, 12:42 AM #9
why do you feel there is a need for this ?
most overnite successes usually take at least 10 years
Certified turd polisher,
06-04-2022, 02:08 AM #10
I use it to build model boats. The picture in my avatar has sponsons made with wood veneer glued to foam with 5 minute epoxy. Lightweight and has survived a bunch of 70+mph blowovers. It's strong in that application, but if you have any kind of large surface area, I doubt it would hold up very well.
06-04-2022, 05:06 AM #11
Mr fun,
I will be cutting the console and I want to add strength
See post #2
06-04-2022, 06:39 AM #12
I'm following. Keep us updated.
noli liked this post
06-04-2022, 08:56 AM #13
Tague is the guy to listen to ...
I don't like to do glass work .. because, I usually get more on me than I get on the job. Goes for paint too ..
However:
Core is just that. It goes between two sheets of glass mat. You already have the outer skin. I doubt you will need to use a saturated one inch thick foam block between it and the inner wall.
We still have a few big yacht builders in our area. A couple are Chaz friendly and let me do a little floor sweepin~dumpster divin ..
. I can usually find more than enough 1/4" balsa or 3/8" foam to do what I need.
For something that already has body lines or change in direction, (contours to the part) I think something like core mat would be your best bet. Cheap, strong and they will send it to your door.
It's not welding ... so what the heck do I know .. Maybe Tague will come back and give it the Popes blessing ..
https://fiberglasssupplydepot.com/Co....37-width.html
06-04-2022, 10:55 AM #14
I have used that foam to fill-in the transom well on a restoration boat that I did. Worked very well.
06-04-2022, 11:17 AM #15
The strength comes from the fiberglass on the out side, glass shops usually have a big flat table with a sheet of aluminum or gloss Formica that's waxed appropriately ( let the wax fully dry before wiping off haze)
then coat with resin a layer of 12/08 or whatever you your using lay in the foam another layer of the type of glass your using, the best way is to cover with peel ply and hook up vacuum to get everything tight and smooth but not necessary for your application, you will have one smooth side after it's cured you can cut up to size needed, they sell pre cut rolls of glass to put together your cut sections, the foam is just a spacer, it's not like Coosa board used in transoms.We have invented the world; WE see
interesting carbon w/ foam core strengths using resin infusion
By noli in forum Fiberglass and Composites DiscussionReplies: 3Last Post: 03-21-2020, 08:26 PM -
How To ?! Splitting a foam-filled or foam core boat?
By home made tunnel in forum General Boating DiscussionReplies: 49Last Post: 03-20-2019, 09:49 AM -
Wraping hi density foam into tight places without using heat and makingthe foam hard
By tunnels in forum Fiberglass and Composites DiscussionReplies: 11Last Post: 01-22-2017, 05:54 PM -
Divinycell Foam Core?
By tj309 in forum Fiberglass and Composites DiscussionReplies: 30Last Post: 10-03-2013, 04:53 PM -
Building materials/ Foam core/ Fiberglass/ Epoxy
By Mhall222 in forum Parts WantedReplies: 0Last Post: 09-07-2013, 02:49 PM
