Page 30 of 34 FirstFirst ... 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 LastLast
Results 436 to 450 of 501
  1. #436
    Jun 2009
    Georgia
    44 Post(s)
    Hi John
    What's the issue with horizontal crank and oil lubed versus vertical and fuel oil lubricated?
    There are 2 basic types of rotary engines. Oil cooled rotor and charge cooled rotor. In the oil cooled type, oil is circulated inside the rotor to cool it. With a pressurized oil system, the engine can use Babbit bearings like most automotive engines. Oil cooling requires oil seal to prevent the oil from escaping into the combust chamber and burned. It also requires an oil pump and cooler to reject the heat gathered from the rotor cooling. All of this adds to the weight, increased friction Hp., cost and complexity. The upside is the intake charge can be inducted directly into the chamber resulting in very high volumetric efficiency. The orientation of the crank has no bearing on the engine other than for oil return. Most of the automotive rotary engines are oil cooled, aka Mazda.
    The charged cool rotor uses the intake charge to pass thru to rotor to cool it. This eliminates the requirement for oil seals, the oil pump and cooler and the sump. Because of no pressurized oil system Babbit bearings can not be used and roller and/or ball bearings are required to support the rotor and crankshaft. The upside is a much simpler and less costly engine. The down side is a significant reduction in volume metric efficiency due to the torturous path the charge must take to get to the intake chamber and the heating of the charge as it cools the rotor. In addition oil must be mixed with the gas to lubricate the bearings. Once again the crank orientation makes no difference.
    Thus for outboard use the weight, cost and simplicity makes the charged cool rotor the best choice.
    Hope this make sense.
  2. Thanks powerabout thanked for this post
    Likes Instigator liked this post
  3. #437
    Jun 2009
    Georgia
    44 Post(s)
    As a side note to the above about oil cooled engines. OMC actually started it's development work with the oil cooled rotor type. We had a 100 CID 2 rotor running as both an outboard and a stern drive producing in excess of 200 HP. The cost of the outboard version was significantly higher that the current 2 strokes. The I/O version competed with the cost of the automotive engines currently being used. In addition the 200 HP engine allowed the dog house to be removed and a full width rear seat with the engine under it. Because of the weight reduction it would out perform a V-8 in all be top end speed. Because the volumes of the I/O could not justify the tooling and the outboard version was too expensive, the oil cooled program was dropped.
  4. Thanks powerabout thanked for this post
  5. #438
    Quote Originally Posted by Rotary John View Post
    There are 2 basic types of rotary engines. Oil cooled rotor and charge cooled rotor. In the oil cooled type, oil is circulated inside the rotor to cool it. With a pressurized oil system, the engine can use Babbit bearings like most automotive engines. Oil cooling requires oil seal to prevent the oil from escaping into the combust chamber and burned. It also requires an oil pump and cooler to reject the heat gathered from the rotor cooling. All of this adds to the weight, increased friction Hp., cost and complexity. The upside is the intake charge can be inducted directly into the chamber resulting in very high volumetric efficiency. The orientation of the crank has no bearing on the engine other than for oil return. Most of the automotive rotary engines are oil oiled aka Mazda.
    Thanks John
    These days lighter engine means an OMC V8 is normal weight, perhaps today a boosted oil cooled rotary would fit right in?
  6. #439
    45 Post(s)
    RJ - You should write a bio book on the OMC Rotary.
  7. Likes lars strom liked this post
  8. #440
    12 Post(s)
    Have you seen this John?
    Looks/sounds very impressive.
    Have heard of similar before but don’t think any have made it through prototype stages.
    The good is, the man behind the design has the background and knowledge.
    https://www.cycleworld.com/story/mot...bike-unveiled/
    Checkmate 16' 140 Johnson
    Laser 480 (?) 21' w/GT 200
    24' Sonic w/twin 250 Johnsons
  9. #441
    Jun 2009
    Georgia
    44 Post(s)
    Yes I have heard of it before. The engine company has been making rotaries for many years; primarily drone engines. I suspect the bike will be a flash in the pan (cost) and if it dominates will be banned. I seem to recall a similar situation.
  10. #442
    Jun 2009
    Georgia
    44 Post(s)
    Thanks John
    If I remember the 3.5 L V-8 weighed around 235# and produced 450HP. The rotary powerhead was just over 2 L, weighed around 130 # and produced around 300 HP. Knowing what I know today and with todays materials, I believe the same rotary could produce 450 HP weighing less than 100#. Problem is no one today is interested in boat racing to invest the monies required.
  11. Thanks powerabout thanked for this post
  12. #443
    12 Post(s)
    The designer ran Norton Motorcycles successful, multi race winning rotary bike program.
    Norton went belly up and new owners finished driving them in the dirt.
    One of my classic bike mags had a great, in-depth, multi page story on the new bike/motor.
    It is cooled through the crank and he made the rotors wider instead of larger diameter like Mazda did.
    He thought that was a mistake on their part.
    He is getting 220 hp+ from 700 CC’s.
    Agreed on seeing how deep new owners pockets are.
  13. #444
    Jun 2009
    Georgia
    44 Post(s)
    Mazda made the rotors narrower because of emissions. With a W/E ratio of around 4; (rotor width/eccentric value) is the most efficient to reduce the surface to volume ratio; ie. Hydrocarbon emissions. In addition, Mazda used side ports and the intake area in not dependent on rotor width. Thus a narrower rotor gave proportionately more intake are per displacement.
    Norton uses a peripheral port directly into the rotor hsg. and making them wider allows a larger intake port (more intake area) w/o changing port timing. They weren't worried about emissions on a race bike.
  14. Thanks Instigator thanked for this post
  15. #445
    Would dfi on a rotary make a big improvement in emissions to try to get the fuel away from all that surface area?
  16. #446
    Jun 2009
    Georgia
    44 Post(s)
    Direct injection has been tried and helps some on the intake side, but you still have the fuel quench problem on the combustion side. At some point, alternatives to the rotary due to the cost to achieve emission results are more economical. I believe the future of the rotary is as a range extender in electric vehicles, size, weight, lack of vibration. The engine could be optimized to run at a specific RPM driving a generator or specialized uses where power to weight/size are critical.
  17. #447
    John, as always, thank you for the education on this subject.
  18. #448
    so what we need is a ceramic rotor so it becomes an adiabatic engine, no heat loss?
  19. #449
    Clearwater, Florida
    17 Post(s)
    Quote Originally Posted by Mark75H View Post
  20. Likes Instigator liked this post
  21. #450
    Southern California
    30 Post(s)
    How do you quantify cubic-inches/liters for a Rotary engine?
    A) One rotor has 3 combustion surfaces/heads. Therefore, (per each rotor) 3 x combustion chamber area = cubic-inches/liters.
    B) One rotor/combustion chamber. Therefore, each rotor is only designated as only having 1 combustion head. 1 x combustion chamber area = cubic-inches/liters.
    I am wrong to think the rotor engine should be classified as example A. Giving the rotor engine & the conventional combustion piston engine equal footing in engine size comparison.
    Example B, seems to me, to give the rotary engine an unfair advantage in racing classification against piston engines.
  22. Likes Instigator liked this post
