Results 31 to 45 of 63
Thread: Hydrostream Venus
06-08-2021, 10:45 PM #31
Definitely. For the time being, I have a 95 Mariner 2.5 200 EFI Magnum I'm probably going to put on it to run it. The more I think about it, I don't want to run the risk of hitting something in the Suwannee with the 260. I figure the Mariner will push it fine for now until I can get what I want. That 260 will make a fine garage ornament.
06-09-2021, 05:59 AM #32
Screaming And Flying!
- 15,058
- 407
- 1450
- 6006
- 11665
300 XS would be sweet on that boat. Fast, cheap to run and dependable all in one package....
06-09-2021, 12:30 PM #33
7000 RPM
- Jun 2001
- Crosslake, MN
- 2,097
- 43
- 82
- 643
- 595
- 3 Post(s)
Bullhead00 -
That 260 might work great for you if you plan on making a few speed runs a week .... I just don't boat like that anymore.
I live on a 12,000 acre chain of lakes - an average boating day for me is to boat anywhere from 3-8 miles to a bar or a buddies house, have a beer, and then go somewhere else. I may have two in the boat or 4. We may idle for a mile or go 100 MPH for a mile or cruise for several miles at 30-50 MPH. Just depends on the day, but I want a reliable and friendly motor - the 300's from Merc have worked perfectly for that use. I've owned pairs of the 300 Promax ( different motors on two different boats ), the 300XS's, and now the 300X's. They all worked great for the above scenario.
Good luck and have fun.
MDS
bullhead00 thanked for this post
bullhead00 liked this post
06-09-2021, 12:35 PM #34
06-09-2021, 06:03 PM #35
Man, run that 260!!! Early runs are the key to not running into anyone in FL. Xstream and I ran the Calloosahatchee around 9a on weekdays and it was open season......those silly tourists only wake up and jump on their pontoons around 11.
That motor is a beast, pre mix 32:1 and let it loose! Only mod it needs is to lose both black boxes as mentioned above1977 Hydrostream Vector 2.5 Promax
06-09-2021, 09:04 PM #36
06-09-2021, 09:15 PM #37
7000 RPM
- Jun 2001
- Crosslake, MN
- 2,097
- 43
- 82
- 643
- 595
- 3 Post(s)
I wouldn’t be worried about the gas - it’s the not wanting to idle and “ticking time bombs” that I’d be worried about - lol
MDS
06-09-2021, 10:19 PM #38
06-09-2021, 11:27 PM #39
Fill them up and enjoy!
The black boxes are for timing advance/retard. You'll see the detonation box on the port cyl bank side mounted and the idle advance box on the top of motor behind the flywheel. I read of the horror stories with these boxes malfunctioning after I bought my promax...they came off quick. Plenty of info and reading on this process here. This is an old thread of many to give you an idea. It'll take you about a half hour to remove them https://www.screamandfly.com/showthr...al-links/page21977 Hydrostream Vector 2.5 Promax
06-10-2021, 04:31 AM #40
7000 RPM
- Jun 2001
- Crosslake, MN
- 2,097
- 43
- 82
- 643
- 595
- 3 Post(s)
06-10-2021, 06:24 AM #41
I’m with the above. Run it. Make sure water pump is peeing strong and new Merc quicksilver lower unit oil change always a good idea. Ditch the black boxes and have fun!
06-11-2021, 01:16 AM #42
But all this talk of swappin the 260 out for somethin else is killin me.....the horn motors are beasts and are made to be run hard and you can still cruise it without blowing anything up. Read up on taking those silly ass boxes out and premix the hell out of it and you'll be 100%. Any questions on the removal or anything, there are a ton of knowledgeable mechanics here from old school to new school who will get you through whatever.......I just wanna see that Venus hit the agua!!!!
06-23-2021, 10:26 AM #43
Well it should be hitting the water 4th of July weekend. I'm putting a 2001 200XS with Sportmaster on it this week. Can anyone provide any info regarding what I should have the setback at? Is 12" too much? I have an Atlas hydraulic jack plate with 12" of setback that I was going to put on it.
06-23-2021, 03:27 PM #44
I wouldn't go more than 6" of setback. Hydrostreams like to run with motor close to the transom
David - WI liked this post
06-23-2021, 05:57 PM #45
Put the 12 on you should like it
This is a grown mans Hydrostream
Not the toy model
Hydrostream Venus
By vnemous in forum General Boating DiscussionReplies: 0Last Post: 08-26-2010, 02:25 PM -
Hydrostream Venus set up
By R.I.P. in forum Props, Setup, and RiggingReplies: 9Last Post: 06-19-2010, 12:02 PM -
hydrostream venus xt max hp
By R.I.P. in forum General Boating DiscussionReplies: 10Last Post: 08-05-2009, 11:08 PM -
89 Hydrostream xt venus set up
By R.I.P. in forum Props, Setup, and RiggingReplies: 15Last Post: 05-13-2009, 05:24 AM
