Results 16 to 30 of 53
09-06-2020, 06:07 PM #16
Member
- Sep 2019
- Saint Helena Island, SC
- 62
- 10
09-06-2020, 06:25 PM #17
The Historic Photo Master
- Jan 2004
- Florida
- 38,669
- 78
- 1767
- 384
- 20409
- 4 Post(s)
09-06-2020, 06:33 PM #18
09-06-2020, 06:57 PM #19
Practice and seat time and you get some muscle memory going on and it gets a lot easier.
09-06-2020, 07:04 PM #20
Understand that this is not a situation where you learn to set up the boat and then you are done. You learn how to work the wheel to counter the chine walk, but you do that as long as you own the boat. Like Lake Fever said, it becomes muscle memory and you forget that you are doing it, but it is part of driving on the pad.
Per Rock:
"Once I bought my first Hydrostream boating changed forever for me."
Per my hero Instigator:
"I try not to let common sense interfere w/my boat buying decisions."
Pat Gent
cell 954-249-3246
'78 Hydrostream Vandal (being rebuilt)
'86 21' Eliminator Daytona, 300 OMC V-8 (Li'l Toy III)
09-06-2020, 09:45 PM #21
I’ve been boating my whole life and my first pad hull I wrestled with for a whole season, the second season I got the hang of it, the third season I bought my second pad hull with a lot more power and it started to click for me. Very little trim, and my mind is almost like a hair trigger response for getting out of the throttle and when I do trim up I’m wide eyed and ready for full tilt abort. Something like that level of intensity is how my mind is, but the seat time makes it more second nature and a lot more fun.
the chine walk doesn’t bother me much now but those hard to see sharp waves sure do. I try and pick my spotsHydrostream dreamin
09-07-2020, 09:23 AM #22
Supporting Member
- Jul 2004
- Connecticut
- 6,260
- 518
- 204
- 1074
- 1127
The Bravo you have has a lot of diameter. Couple that with no torque tab and possible slight air in the steering and all these items will add to chine walk. IMO find a shop who has a power purge machine and do that steering part first. Then, you might try a Rev 4 and compare it to the Bravo you are running currently. Then you can take on some next steps.
09-07-2020, 11:19 AM #23
Screaming And Flying!
- 15,058
- 407
- 1450
- 6006
- 11665
4 blade should settle it down some and allow more positive trim too.
09-07-2020, 11:49 AM #24
09-07-2020, 01:18 PM #25
Member
- Sep 2019
- 62
- 10
09-07-2020, 02:42 PM #26
09-08-2020, 10:39 PM #27
I'm in the same boat...learning my shadow. I found these links helpful.
https://basscat.com/forum/groups/bas...nd-bow-torque/
http://www.bassboatcentral.com/new_page_2.htm
Play with your motor height, too. Too deep adds to poor handling.
Lastly...do NOT get out of the gas quickly when at speed!!!!! It's real easy to hook one by doing that. Trim down a few bumps to set the keel in the water and THEN get out of the gas.1990 Shadow bass boat w/ 2.4 200 Merc. Totally resto'd boat and love it!
JR IN JAX liked this post
09-09-2020, 06:29 AM #28
Rgsauger thanks for that tip. I haven’t been fast enough yet to deal with major abort issues but I roll out of the throttle and trim down simultaneously. Nothing abrupt just instant reaction when it feels sketchy I get out of it and start again. Plus I run a v-king which tracks good on the deceleration.
Valero, two v-kings and a vandal which isn’t fast yet. Wanted this info here in case my advice doesn’t work for another hull I don’t want to steer anyone wrong. I’m still a newb and just lived this pad learning thing too is why I commentedHydrostream dreamin
09-09-2020, 08:57 AM #29
Member
- Sep 2019
- 62
- 10
09-09-2020, 12:50 PM #30
So in my lack of experience, I hooked it three times over a couple of years and didn't know why. Started reading EVERYTHING on the topic and the consistent theme was getting out of the gas too quickly. Basically, the hull is up and out of the water on the pad and is slightly skewed from prop torque. So when I essentially chopped the throttle, it dropped the keel back into the water but at a slightly off-from-center angle and she hooked like a bittch to the left pretty hard. Now, bump bump on the down switch and then back out of it - not a prob.
Learning the pad...get just into the pad and hold it there and learn what she does and why she does it. You're never more than one or two bumps down from "stable" and safe. Have fun, wear you life jacket and kill switch, and don't get wet! lol1990 Shadow bass boat w/ 2.4 200 Merc. Totally resto'd boat and love it!
Chine walk
By jeff wilson in forum Racer's HangoutReplies: 11Last Post: 07-06-2010, 09:19 AM -
chine walk
By macutty in forum Props, Setup, and RiggingReplies: 31Last Post: 12-06-2007, 12:12 PM -
Got thru chine walk...now what?
By tj309 in forum Technical DiscussionReplies: 7Last Post: 08-22-2007, 01:57 AM -
chine walk (help)
By captain chris in forum Technical DiscussionReplies: 9Last Post: 06-27-2007, 11:16 PM -
Chine walk help
By Lockjaw in forum Props, Setup, and RiggingReplies: 15Last Post: 06-26-2006, 04:08 PM
