    Feb 2008
    Milan 1983..My first F1-V8 heat win.
  2. #6782
    45 Post(s)
    Smoke Trails?
    Quote Originally Posted by lars strom View Post
    Engines all on fire? (LOL). Who rigged the smoke packs?
  3. Thanks lars strom thanked for this post
    Likes lars strom liked this post
  4. #6783
    Feb 2008
    @WaterZebra
    Benson & Hedges commercial.
  5. #6784
    Aug 2013
    Stanwood, Wa.
    I love some looper offshore action, 1989 Carry le Rouet. Just listen to those Johnson GT200's! Racing starts at 1:50.
    https://www.youtube.com/watch?v=gZrJGbxkQWg&t=230s
    91 Seaswirl 178 spyder sport. Evinrude XP175. (59 MPH, so far, and so close).
    85 Sleekcraft SST , 225 Johnson...(sold)
  6. Thanks lars strom thanked for this post
    Likes lars strom, Instigator, sharpeye Mike liked this post
  7. #6785
    Feb 2008
  8. Thanks z1rider thanked for this post
    Likes msm liked this post
  9. #6786
    11 Post(s)
    Killer video!
    Quote Originally Posted by z1rider View Post
    Checkmate 16' 140 Johnson
    Laser 480 (?) 21' w/GT 200
    24' Sonic w/twin 250 Johnsons
  10. Thanks lars strom thanked for this post
  11. #6787
    Feb 2008
    Liege 1984..the start.
  12. #6788
    Feb 2008
    Ron Hill driving a Scotti-Craft with a Johnson V4 Stinger GP..never seen Ron driving a Johnson before..!!
    I guess Long Beach, CA
Name:	ron holl johnson.jpg
  13. #6789
    Feb 2008
    A Frenchman in a Cormorant (is my guess) and power by the Evinrude V4 Super Strangler.
  14. #6790
    Feb 2008
    Evinrude G2 Offshore racing.
  15. #6791
    Connecticut
    Charlie Strang was called upon to design a Racing Gear Case with Forward-Neutral-Reverse because it was an APBA Class requirement at the time. Subsequently, when the competition shifted to 99 cubic inch motors, the shift requirement was eliminated. Charlie was an Executive for OMC at the time, and during a plant wide annual shut-down, he went into the Engineering Department, sat down at a Drawing Board (this was long before the days of Computer Graphics), and over the course of several days, he designed an absolutely fabulous forward-only Racing Gear Case.
    Just as in his Full Shift Gear Case for the 89 cubic inch Johnson GT-115, the Direct Drive Gear Case was a twin Pinion Shaft design with both Pinion Gears driving the same "Bull Gear". The "Bull Gear" was one part with gear teeth on both the forward and aft sides of the same part. The way I understand it, the "Bull Gear" had a female spline on the ID and was mounted on a male spline on the shaft, in much the same was as a Clutch Dog is on an OMC conventional shifting Gear Case except the forward-aft movement of the "Bull Gear" is extremely, extremely small in comparison. Charlie's Racing Direct Drive Racing Gear Case was assembled from the front and permitted a much better hydrodynamic forward-to-aft taper leading the Propeller. During the set up of the Racing Gear Case, Shims must be used on the Pinion Shafts and the driven shaft, and this set up must be performed by an experienced OMC Racing Gear Case Technician. When properly set up, Charlie's Design essentially ensured equal loading on the twin Pinion Shafts and their respective Pinion Gears.
    Charlie's Racing Gear Case Design was used on the 99 cubic inch, V4, Johnson Model KC-13R "Stinger"; the 99 cubic inch, V4, Johnson Model KR-15M "Stinger GP; the the 121 cubic inch, V6, Johnson "Singer GP"; the 4 Rotor Johnson Rotary Combustion Racing Engine, and list goes on and on to the Racing V6 and Racing V8 Formula One Outboard Motors. The way I understand it, if the OMC Racing Outboard Motors were only used by Factory Drivers, then those Racing Outboard Motors did not have a Model Number.
    Charlie was a Racer himself for many years back in the 1930s up until WWII, and he was also a brilliant engineer who had the passion, drive and understanding of Outboard Boat Racing. Charlie Strang's contributions to Outboard Boat Racing are Legendary.
    Hope that this helps.
  16. #6792
    Feb 2008
  17. Likes Instigator, STEVERINO liked this post
  18. #6793
    Feb 2008
    EVINRUDE STILL HOLDS THE RECORD - The record for the fastest speed for an outboard powered boat is 176.556 mph (284.14 km/h) set by Bob Wartinger (USA) in a Karelsen hull powered by a 3.5 litre Evinrude V-8 on the Colorado River neat Parker, Arizona on November 30, 1989. Running at close to 10,000rpm with a overdrive gearcase, this incredible motor powered a 20 foot, 3-point hydroplane to a 2-way average of 176.556mph. During testing it easily exceeded 190mph but was damaged after hitting an object in the water. It was expected to exceed 200mph until than unfortunate incident.
  19. Likes Instigator, msm, STEVERINO, Lake X Kid liked this post
  20. #6794
    Southern California
    30 Post(s)
    Quote Originally Posted by Bob Zipps View Post
    To Shim properly to ensure "equal loading" to me, seems to me to be as much art as science. How can one "ensured equal loading" were the gear case obstructs the view (measurement gauge readings) of the contact areas?
    I wonder if the experienced Technician, is relying on his feel when he turns the shaft by hand.
  21. Likes Instigator liked this post
  22. #6795
    Jun 2009
    Georgia
    43 Post(s)
    Ward Cox was the gearcase man for OMC when I was involved. He rebuilt each gearcase after every race
  23. Likes Instigator, STEVERINO liked this post
Page 453 of 894 FirstFirst ... 353 403 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 503 553 ... LastLast
  1. Evinrude & Johnson Racing 1967+
    By Mark75H in forum Outboard and Racing History
    Last Post: 04-24-2023, 09:58 PM
  2. V8 Johnson/evinrude Outboards
    By baassoc in forum General Boating Discussion
    Last Post: 04-17-2020, 06:21 AM
  3. D and E Class OMC outboards, Johnson 60 and Evinrude 75
    By smokin'joe in forum Outboard Engines
    Last Post: 05-21-2017, 09:24 AM
  4. Replies: 0
    Last Post: 10-02-2014, 09:07 PM
