    45 Post(s)
    Dashboard PT
    I have that gauge and switch set new in the box somewhere in my barn? Definitely the way to go until they integrated the switches with the throttle and shift lever. Did the trim indicator gauge work with outboard PT? I never used the gauge with outboards...…...far too easy to just look back at the engine.
  3. #17013
    Quote Originally Posted by WaterZebra View Post
    yes they did. and many were in use back then with this same trim button arrangement. but...although the trim gauges at a glance looked identical, there was a gauge for outboards, and a gauge for sterndrives. different part numbers. many times the part numbers were labeled/visible on the backsides of the gauges for reference. get the part number off the gauge you have, if still there, and attempt to research it as an o/b or an I/o trim gauge on the internet. the three button trim panels were the same for o/b and I/o.
  5. #17015
  6. Likes Capt.Insane-o liked this post
  7. #17016
    Feb 2003
    peoria il
    I was able to connect the ram end with thick aluminum plates bolted from the outside of the swivel.
    And yes you have to reverse the the pump lines to avoid bleed down found that out also.
    Dale
  12. #17021
    Feb 2003
    peoria il
    Speaking of trim indicators this has has to be a rare one.
    Early twin IO.
    Dale
    Attached Thumbnails Attached Thumbnails 23075-bxp-vintage-complete-dual-trim-indictor-48285a3-8-1-2-x-4-3-4.jpg
  13. Likes Capt.Insane-o, powerabout liked this post
  14. #17022
    ...This is a photo of the Mercury Power Trim Cylinders in conversation above. Note that the engine is fully trimmed/tilted up, yet the cylinders are fully retracted...
  16. #17024
    ...this is a photo of this trim system with the engine completely trimmed in, or in the down position...
Page 1135 of 1891 FirstFirst ... 135 635 1035 1085 1111 1112 1113 1114 1115 1116 1117 1118 1119 1120 1121 1122 1123 1124 1125 1126 1127 1128 1129 1130 1131 1132 1133 1134 1135 1136 1137 1138 1139 1140 1141 1142 1143 1144 1145 1146 1147 1148 1149 1150 1151 1152 1153 1154 1155 1156 1157 1158 1159 1185 1235 1635 ... LastLast
