Results 16 to 30 of 40
    Jul 2005
    AZ
    Ain’t never had no problems, ‘cept buggered guide tubes. I’m a thinkin if ya melt tha pump it ain’t had no water in it (don’t dry start it ever), or ya puttin out more than ya can get rid of and need a little xtra relief
    Rgsauger Don't mean to high jack..it's in context
    Was that evinrude looper ?
    I'm installing new mids will have plenty of relief but new and fresh paint DONT want to ruin it..
    Maybe pump was a fluke? I've never dry started if I did would drop it and change pump...I don't even use the crappy fitting flushers even the newer orange ones suck
    Did try them thought they would work..might work better on other stuff but didn't work well enough for me
    I've always used hose w tubes
    These will have plenty if relief between that and drilled lower and back of mids..
    If everyone is saying it's fine looks like I'll be leaving them out too!
    Want Evinrude OMC to chime in
    Oh that bottom pic is when it started that's before it got bad looks like it's started to bubble from heat ran a blade over it knocked off the top of the bubbles
    Michael
  2. #17
    Black Creek WI
    When I use a bass mid (stock) I drill the relief holes, five 1/2 holes on each side of the mid. Yes the paint fades and gets that chalky look, but with the relief holes drilled in the mid, haven't had any trouble with water pump melting. Just my 2cents
    1994 Brad Collins Mirage Jag.with 1990 2.4 BP E.F.I Offshore
  3. Thanks rgsauger thanked for this post
    Likes mrichartz liked this post
  4. #18
    May 2014
    Livingston, Louisiana
    Michael
    Sorry, I wasn’t clear. I was speaking about the Mercs. Not sure on the looper. But thinking as long as ya got enough discharge water spraying toward pump and mid you’d be ok.
  5. Thanks mrichartz thanked for this post
  6. #19
    Houston, TX
    Michael
    Hijack away, bud. I never understood how some folks get their panties in a wad when someone injects something different into a thread. I appreciate folks' feedback on here. Life's too short to have to learn everything from my own mistakes!
  7. Likes mrichartz, FORBESAUTO liked this post
  8. #20
    Feb 2011
    HUDSON, FLORIDA
    If your concerned about your mid getting too hot for your nice paint think i found the answer. i wrapped my tuner with some old thermo-tech header wrap from my drag racing days. i secured it with ss piano wire, starting from the adaptor working towards end, overlaping as i went. its not effected by water. most speed shops sell it. keeps the heat in, wear you want it. im thinkin, thumbs-up??
  9. Likes mrichartz liked this post
  10. #21
    Jul 2005
    AZ
    Quote Originally Posted by KIRCHNER View Post
    I'm not worried if I leave them in...rgsauger was asking taking them out then I thought about it but w/o exhaust liner is when I think it will burn... I will probably leave them in I have enough exhaust relief between the new mids drilled in back ,the offshore out the back and the lower unit drilled
    Michael
  11. #22
    Shawano,WI
    SO...if I put a liner(what you guys are calling a can) in a 260 bass mid and direct all exhaust to the lower it won't hurt performance or hurt the motor and everyone on the lake will hate my boat less? LOL! As far as the paint goes, it just gets a chalky film on it. It's not really the paint itself that discolors.
  12. #23
    Jul 2005
    AZ
    Quote Originally Posted by PaulR View Post
    Thats where it's confusing..talking about a different animal..lol.
    On mine the paint bubbled and burned but again it's an evinrude different exhaust flow?
    I've got plenty more exhaust relief with new mids...w/o the liner would probably be better on mine with what's been done and no airboxes..will have to make a decision soon..
    And NO WAY do I care about the neighbors hell you should here my truck all stainless custom exhaust long tube headers High flow cats and Corsa muffler loud as hell.. luckily I couldn't stand the neighbors before so parked with exhaust facing his house would wait till 7:00 to make the school run w my daughter the rest of neighbors were at work or left but drove them nuts..lol..told him guess you shouldn't of let that tree fall on my garage then started running the boat up there on the hose.
    Michael
  13. #24
    Houston, TX
    That's a pretty slick idea...........
  14. #25
    Houston, TX
    From what I can tell..........yep
    I'm not necessarily drilling mine down low, just yanking the can. If I did, I would tap the holes while I was in there to plug them if ever needed
  15. Thanks half fast thanked for this post
  16. #26
    Shawano,WI
    Quote Originally Posted by rgsauger View Post
    If your not going to drill it, leave the liner in. Whatever you do, DON"T drill two big holes in the back of the CAN/MID I guarantee it will crack!
  17. #27
    Jul 2005
    AZ
    Maybe I'll do some testing with a heat gun, torch and the ir-gun see what happens when I heat it up to 180-200 or so
    On another mid first..easy enough to go with an old mid off...just have to paint it the same day as the lowers paint only lasts 24 after you start w it.
    Michael
  18. #28
    Houston, TX
    No way I'm drilling the back of the mid!
    It sounds like a bunch of the Promax's were drilled down bottom from the factory with the 5 - 1/2" holes on each side of the lower. Even though it's not very thick, could probably tap them enough to get an allen plug in from the bottom if you wanted to close if off.
  19. #29
    Jul 2005
    AZ
    Figured hell with it just heated one of the mids in the front to 180 didn't blister or anything was just a small area.. but was a little soft I haven't left them out in the sun and baked them yet..it's been chilly here still too.
    And as fast as I could move they would cool down fast.
    Michael
  20. #30
    Houston, TX
    1720 degrees!!! MY GOD!!!!!!! what did you use, a blue tipped gas ax??????? lol
    Ahhhhhh, the difference a decimal can make!
  1. Counter-rotating looper lower, any drawbacks to
    By Sleekster in forum Technical Discussion
    Last Post: 02-06-2002, 11:16 PM
