Page 3 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 31 to 45 of 63
  1. #31
    With all the back and forth it's easy to forget that someone still makes a 2 smoke.... I admire BRP for sticking with it.
    the rest gave up as they had no technology for making an emission compliant 2 stroke.
    Wait till they measure CO and or the EPA find out how bad 4s are then they will all need cats
    Did you wonder why 4s run so rich so stink out the marina like they left the choke pulled out....to reduce NOX at a huge cost to CO
  2. Likes loop, keefallan liked this post
  3. #32
    Outboards are two strokes, the rest are Hondas
  4. #33
    Galveston County,TEXAS
    Quote Originally Posted by slowJEEP View Post
    That RAVE valve only adds 10 HP. Seems like a lot of complication for 10HP. Is there another benefit besides peak HP?
    RAVE valves are extremely simple and have been proven to be reliable through many years of use. 10 peak hp may not tell the whole story as its more likely that they allow more power across the power band
    limited skills
  5. Likes Cornchip, David - WI, WavetoWave liked this post
  6. #34
    Jun 2019
    Ontario Canada
    This engine design will hopefully trickle down to the 75-90 I hope with time. Would it even be practical to loose a cylinder and make a 1.3 liter block with such large jugs? I could honestly care less with the exception of weight,fuel range and a good strong charging system. I'm not asking for much.
  7. Likes WavetoWave liked this post
  8. #35
    Sep 2017
    Miami
    Yes, the PROXS with the small case. Limp biscuit, going to need a head to head to find out the Merc sucks.
    Trolls wonderfully quiet can't complain except it couldn't break 34 mph with 3 people no gear and 38-39 with two people going with the 1 1/2' chop at 6300 trimming for miles to get it there, different props didn't help. Lund 18' new boat.
    I'd take the new one, Makes lots of power. I believe there is a XB2002 doing mid 70's with one.
  9. #36
    Wet noodle of a motor from all I've seen but maybe on the right light areo lifting hull it does better. I tried the WOT from idle, blah. Mid range cruise is not effortless. We all scratched each others heads. Nice stickers and black is slimming but still a big girth in a tight dress.
  10. Likes Capt.Insane-o liked this post
  11. #37
    Quote Originally Posted by loop View Post
    The valve, optimum port to port blowdown pulse arrival by delaying it at low rpm, effectively lowering the port roof.
    Maintaining the arrival in the optimum efficiency range prior to port closing throughout the entire rpm range. Without the valve arrival is much earlier at low rpm which is detrimental to hp. The valve is programmed for rpm and likely load, throttle position and rpm to insure high loads at low to mid rpm are easily powered through by maintaining the low port as needed until the boat breaks free. Far more hp where you need it. Then raises the port to get the maximum from the actual duration at the big end. Sweet motor, add to that a thinking fuel and ignition so to speak.
  12. #38
    Sep 2017
    Miami
    Evinrude needs to do another one of their "Challenges" a showdown with all the popular 115's on the same hull, and 150's on the same hull.
  13. Likes FMP, keefallan liked this post
  14. #39
    Yes let's see it . I'm sure they did just that when setting the final tune and ensuring EPA certification prior to release. Can't have the other guy take the lead and win. Stern to stern tug of war?
  15. #40
    Sep 2006
    Sweden
    Never thought I would say that the new e-rude in not uglier than the new merc. They are about equal. I thought I would get used to and start to like them. But nooooo....Just can't...
    I think the Mercs are butt ugly and the new Evinrudes look nice. Mercury failed miserably lately - their engines look like d*cks especially from the rear.
    RIB Unlimited 600/Merc 150 ProMax ss
    Allison SS-2000/Merc 200xs ss
    Hydrolift T-17/Merc 200xs ss
  16. #41
    Sarasota, FL
    it's a 2 stroke......
    Oh duh!! Its too early was only on my second cup and prob should have read more lol.
    Rob Lankford
    1988 20' Action Marine 2.4 200
    Previous owned boats worth mentioning
    1976 17' Action Marine 2.4 200
    1984 20' Action Marine 2.5 200
    1983 17' Hydrostream V-King 2.4 Bridgeport
    2003 LPB STV RR COPY 2.5 280 /300 Drag
    2005 LPB STV RR COPY 2.5 280
    2005 Baja 23 Outlaw 6.2 Mercruiser
    2006 FTP Quarter Shot T3 Race 2.5 200 CARB/2.5 225 PROMAX
    2009 FTP Quarter Shot T3 Race 2.5 280
  17. #42
    Central, PA
    Quote Originally Posted by aeneas View Post
    New mercs are definitely ugly , etecs are also hideous. ....I wish these companies would just ditch all this mid cowling nonsense and get rid of the pointy tops. Remember when outboards actually looked like outboards?
  18. #43
    Merc Alien cowl was and still is ugly, they started it...
  19. #44
    Lake Coochiching, Ontario
    I like the alien cowl, but not the G2 or new 300R looks.
    the new triple is bigger than 1/2 of 3.4
    is the next motor a bigger V6?
  20. #45
    Strategy
