Results 1 to 13 of 13
04-29-2019, 07:09 AM #1
Finally got the Circus Circus conversion done!
I thought some of you might like to see the nitro to electric conversion I did on the Dumas Miss Circus Circus. I built the boat about 25 years ago and put a Picco 80 in it, I was never able to get it to run right, so it went on the shelf. I recently pulled it down and converted it to electric. .
TP Power 4070/1090KV, 2-4S 70C Graphene pacs, Castle Mamaba XLX that I converted to water cooling. It was a tight fit getting everything in and keep it balanced...hopefully it runs good...we'll see
04-29-2019, 11:37 AM #2
6000 RPM
- Sep 2002
- Solvang, Calif
- 1,459
- 78
- 29
- 160
- 156
Nice!
Gary
04-30-2019, 06:23 AM #3
Thanks, turned out to be a much larger project than I thought it would be...
04-30-2019, 11:05 PM #4
6000 RPM
- Sep 2002
- Solvang, Calif
- 1,459
- 78
- 29
- 160
- 156
Question. The last two pictures... is that the speed controller and it's heat exchanger?
Gary
05-01-2019, 06:33 AM #5
Yes, It started off as a Castle Mamba XLX...which is an ESC designed for rc cars. It comes packaged with an aluminum heat sink and cooling fan attached. I gutted it down to the the
circuit boards and removed all the factory thermal compound. I then fabricated the 4 copper heat sinks with cooling tubes. They are also tin plate to stop any corrosion. The heat sinks are clamped to the four high current
busses on the power circuit board with silicone based thermal compound between them. I also coated the circuit boards in Glyptal to water proof them. All this adds up to increasing it's current rating by almost a factor of two.
approx.300 amps peak (stock form it is rated at 160amps). The Castle controllers, along with other mfg's have data logging capability. You can plot rpm, temp, voltage, ripple voltage, current along with a host of other settings.
This has been a tremendous learning experience...the brushless motor technology has really evolved.
Sorry for the long winded explanation....I guess "yes" would have sufficed
05-03-2019, 11:15 AM #6
5000 RPM
- Feb 2017
- Wixom lake michigan
- 177
- 40
- 9
- 293
- 34
That sucker should rip! Looks very nice
05-03-2019, 03:00 PM #7
6000 RPM
- May 2001
- Maine
- 1,088
- 13
- 41
- 105
- 213
I have a Miss Budweiser 1/8 I was thinking of doing the same retrofit to. It was set up with a .67 picco but now days electric or gas for me is the way to go
05-06-2019, 06:37 AM #8
I still haven't had a chance to run it, but I'm sure that will be a learning curve also. Should be interesting to see if it will run similar to nitro power.
These older boats are pretty tight in the engine compartment, it took some doing to get everything installed and still balanced correctly. Mine is still a little tale heavy, may have to add some more weight up in the nose.
Offshore Electric forum is a good place to go if you need help.They also have an online store that has been invaluable....real brick and mortar hobby shops are a thing of the past
OnPad liked this post
05-08-2019, 10:41 AM #9
Very nice conversion. Clean.
1970 15' Allison/135 Chrysler stacker
RC Mod-VP Boats
IMPBA District 13
NAMBA District 3
05-15-2019, 03:08 AM #10
That is nice. What is the weight diff. between fuel and ele.?
93 STV Mod VP/MERC 2.5 200
Proverbs 4:18-20
-- John F. Kennedy 1962
05-15-2019, 06:20 AM #11
I don't know for sure, but the hull with running gear and no motor weighed 9 lbs.
I would guess the brushless motor is about the same weight as the Picco 80, maybe a little heavier. So the only additional weight is batteries and ESC. Batteries are about 1.3 pounds each... times two, and the ESC maybe weighs .25 pound
10-11-2023, 06:20 AM #12
New Member
- Jun 2019
- GROVETOWN, GA
Very nice! What did you use for the color of the boat, paint or vinyl ? Everything looks straight , all the outlines of the colors and cowling lines.
12-16-2023, 09:13 AM #13
The Pirate Circus Begins
By transomstand in forum The Scream And Fly LoungeReplies: 33Last Post: 02-17-2011, 12:29 PM -
any nitro circus fans on here ???
By PARKER RABE in forum The Scream And Fly LoungeReplies: 25Last Post: 01-09-2010, 12:11 AM
