Results 1 to 6 of 6
    If you had a "Big Johnson"
    Would you start your need for speed with the cavitation plate below the bottom of the boat, even with the bottom, or 1" above the bottom? (lets call it a delta pad bottom)
    Thanks guy's, its been quite a while for me. NP
    Ft. Lauderdale, Fl
    Depends on the boat and the prop you wanna use..... but al in all.... the cav plate will always be above the bottom of the boat.....
  3. Thanks NICE PAIR thanked for this post
    Jun 2017
    Possum Kingdom Lake Texas
    Lmao!
  5. Likes NICE PAIR liked this post
    1'' is a safe bet with a variety of props. You don't want your johnson to be over exposed to air cause it will get hot....Nobody wants a overheated johnson. Big or little size....
  7. Thanks NICE PAIR thanked for this post
    Oct 2018
    Tennessee
    If you start surfacing, you might want to pin the carrier bearing.
  9. Thanks NICE PAIR thanked for this post
    Likes JrCRXHF liked this post
  10. #6
    May 2002
    Lake Havasu City AZ
    The boat make and size makes a huge difference. On my 20’ Stoker I ran the prop shaft 1”above the pad now on my 26’ Advantage party cat with a V8 E-Rude I tried to go up until the top pick up hole in the lower was level with the pad and it was 1” to high and would not carry the bow.
  11. Thanks NICE PAIR thanked for this post
  1. V8 Johnson Limited Edition "Second Effort"
    By jimbo1 in forum General Boating Discussion
    Last Post: 02-26-2021, 12:03 PM
  2. 400HP "Evolution Marine" Johnson V8 (Blown Powerhead)...
    By skywalker26v in forum Outboard Engines
    Last Post: 04-03-2018, 10:36 AM
  3. "Sum Ting Wong," "Wi Tu Lo," "Ho Lee Fuk" and "Bang Ding Ow"
    By STVmod in forum The Scream And Fly Lounge
    Last Post: 07-15-2013, 09:34 PM
  4. Replies: 5
    Last Post: 02-13-2011, 09:18 AM
