Results 1 to 14 of 14
Thread: Anti cavitation height?
06-10-2018, 09:44 PM #1
Junior Member
- Sep 2016
- Starkville,MS
Got a 1980 model Mercury V225 on a 19ft 1993 Hydra Sport LS180. Having holeshot issues. Once it planes it runs fine. Had a Mercury Fury 24p that pushed it 62 mph but hell getting out the hole. Just put an aluminum 23p Mercury prop on it. Better but still crappy performance out of the hole. 53 mph on 23p. From pad is 2.75 inches to bottom of cavitation plate and 5.5 from center of prop spline to pad. Is this even close to right? 80psi each cylinder cold. 90psi hot.
06-12-2018, 11:57 AM #2
IMHO those #s mite b ur whole prob, but ur height of motor is pretty close to where it needs to be , perform a leak down test if possible, what is ur wot rpm?
06-13-2018, 06:34 AM #3
She's tired....
90 5.0 liked this post
06-13-2018, 01:22 PM #4
Junior Member
- Sep 2016
- Starkville,MS
06-13-2018, 01:23 PM #5
Junior Member
- Sep 2016
- Starkville,MS
I'm afraid you are correct!
06-13-2018, 06:39 PM #6
Seems to me that motor should run those rpms with a 25 or 26 prop,, id say needs rings,if you was to tear it down now could possibly just do rings and bearings tho,if you keep running it could possibly do more damage to sumthin
06-14-2018, 01:50 PM #7
Junior Member
- Sep 2016
- Starkville,MS
06-21-2018, 12:07 PM #8
7000 RPM
- Feb 2005
- seattle
- 2,654
- 17
- 33
try na set of doel fins. at $40 it a quick solution for hole shots. i've had a set on all my motors since 85. if you look at the older race boat they all has fins on the cavation plates.
06-21-2018, 03:59 PM #9
It looks to me like you're at least 2 inches too deep. And, if compression gauge is right it's getting tired.
I carry a gun because a cop won't fit in my pocket.
1987 Glasstream 15V
1986 Mariner "Tower of Power" 115
06-21-2018, 08:26 PM #10
6000 RPM
- Feb 2014
- Missouri
- 1,212
- 66
- 12
- 83
Looks tired.
But hows your trim angle when you take off. To far out and you push down and torque the bow up. To much in and about the same look but it tries to lift the stern and bow will come as well. Neither will give a good whole shot.
Odd question but what’s the stall speed as you come out of the hole. If it hangs 3500-4000 things are probably good just tired. If it hangs 2500-3000 you would have a look for something half broke or to much pitch. 3000-3500 is decent and just depends on how long it hangs.
Some old old stuff even when new just didn’t get up on plane well. Old bass boats loaded would take 7+ seconds till the bow would start coming down. Vented props helped a lot when they came around.
06-23-2018, 06:22 PM #11
Supporting Vendor
- Sep 2006
- Key Largo, Fl
- 3,351
- 259
- 30
- 715
That motor was not very powerful on the bottom end from the beginning, should have around 125 pounds of compression, if it’s 80 to 90 it’s not tired, it’s asleep, Chris
06-24-2018, 12:06 PM #12
'bout 3.5 inches pad ta center prop shaft (startin' point) but if ya have faith in that gauge movin' tha motor, like indicated, won't do much good...………….
06-24-2018, 06:12 PM #13
Remember that's a 38 year old motor. Rebuild NOW before it really gets expensive.
1987 Glasstream 15V
06-24-2018, 06:23 PM #14
How's it idle?
Get a new compression tester and report back.Azure AZ259, 8.1
need help setting my engine height and jack plate height
By johnsongt175 in forum Props, Setup, and RiggingReplies: 2Last Post: 05-27-2014, 07:21 AM -
cavitation
By bec in forum Technical DiscussionReplies: 0Last Post: 09-30-2009, 07:43 PM -
merc anti-cavitation ring
By mercrazy in forum Technical DiscussionReplies: 3Last Post: 10-19-2008, 06:28 PM -
HOW to - jack plate height/engine height
By Techno in forum Technical DiscussionReplies: 4Last Post: 08-21-2007, 12:49 PM
