Results 1 to 2 of 2
    Mar 2015
    bunnell FL/old town FL
    Sportmaster lower shift shaft seal
    I noticed fluid coming from the top of the lower unit ,I had just replaced the shift shaft seal, went in nice and tight when I removed it the shift shaft seal was 1/2 out . I know people say to let a little fluid out when u change fluid am I maybe not letting enough out and the pressure is pushing it out ? Thx for any info
    2003 mirage ski racer with e-tec power
  2. Likes NICE PAIR liked this post
    Quote Originally Posted by Dan sos express View Post
    I believe the correct amount of lube in the sporty (dry) is 28oz. If I had to guess dry to overflow would be a quart + lets just say 33/34 oz.
    I've had very good luck when done filling with motors vertical, I take out the top plug and let it temp-cycle (open-drip) for two days, then cap it up.
    you probably could (with the top plug in) pull the bottom plug and drain off 2oz.
    my $ .02
  4. Thanks dgscroggs thanked for this post
  1. Lakeland marine shift shaft seal
    By bradmd in forum Four Stroke and Direct Injected Two Stroke Engines
    Last Post: 03-02-2018, 06:30 PM
  2. 3.0 Sportmaster Billet Seal Housing & Shift Shaft Housing
    By alli-runner in forum General Boating Discussion
    Last Post: 12-27-2010, 08:25 PM
