Results 481 to 495 of 740
Thread: Looper exhaust porting
02-07-2018, 08:43 AM #481
Update:
Head studs finished! (Shown in another thread)
Rods freshened up with 400grit wet paper:
Upper main bearing removed from its carrier:
I placed the bearing carrier on a steel pipe in the owen.
Once it reached 450 degrees the bearing dropped right out.
Just clean and repaint the carrier before applying heat and a new bearing and a new seal.
olboatman liked this post
02-09-2018, 04:40 AM #482
02-10-2018, 11:11 AM #483
What do you guys think of this:
Found it on this cite:
http://richstaylordporting.com/moder...kePorting.htmlLast edited by Captain75; 02-10-2018 at 11:23 AM.
02-10-2018, 05:33 PM #484
a gimmick.
total waste of time and effort. and a patent as been applied for by a Pakistani !!!, that alone should tell you straight away its a con.
its a way of making the combustion chamber bigger again if you have skimmed to much off... no science behind.
another one of gupta's daft idea's that a lot of mugs will pay for to help slow down their motors.
idiots saying how much its improved the power especially when they decked the block and skimmed the head !!!! err object defeated.
02-11-2018, 03:35 PM #485
02-11-2018, 03:50 PM #486
Screaming And Flying!
- Feb 2015
- Ontario
- 8,124
- 205
- 324
- 1938
- 2015
Dimpling quench area has been dyno proven, V8 auto. Also port passages.
02-12-2018, 02:59 PM #487
Today it was time to fill the idle reliefs...
Took a plastic syringe of about the same size as the relief holes.
Cleaned the holes with acetone and plugged them in the bottom using parts of a foam earplug.
Of course I managed to create some mess on one of the cyls due to exessive amounts of JB. Tried to clean the bore fast with acetone, so I hope it didn’t end up clogging the cross hatches next to the relief hole.
02-12-2018, 04:33 PM #488
5000 RPM
- Sep 2009
- iowa
- 679
That's exactly how I filled my relief holes. Keep up the good work!
1975 Hydrostream Ventura II
1987 evinrude 200xp
02-12-2018, 07:22 PM #489
that crank has come up very nice indeed.
the idle reliefs look as though they should stand up ok, but from my understanding of the idle reliefs and how they work, is to give a far
smoother idle, but from above 2000 rpm they dont do anything at all !!! so where is the gain in filling them in ?
will they make a difference to mid range rpm and top end if no other mods were done ?
this is something I have not done ( yet) as I have had conflicting advice on the idle reliefsLast edited by phillnjack; 02-12-2018 at 07:25 PM.
bigbluechevy454 thanked for this post
02-12-2018, 11:31 PM #490
6000 RPM
- Sep 2002
- Solvang, Calif
- 1,459
- 78
- 29
- 160
- 156
" so where is the gain in filling them in ? " Compression.
Gary
Freddie Webb liked this post
02-13-2018, 04:13 AM #491
The method works fine doesn’t it?
When I do the other bank this evening, I will grease the bore after clearing the relief hole iot prevent any epoxy from ending up in the bore.
Clogging the bore’s cross hatch, thats the only thing I’m a bit worried about right now. I will try to inspect it with a magnifying glass. I hope it won’t need another round with the Lisle 15000!
phillnjack liked this post
02-13-2018, 10:39 AM #492
why not just put tape around it and then poke a small hole in it.. any glue from the tape can be wiped off afterwards.
02-13-2018, 11:13 AM #493
I’ve tried that, the problem is the air pocket that is being created between the bottom plug and the epoxy being poured in. You need to work it down there and thats why it becomes messy... With tape some of the goo easily finds its way in under the tape
I am probably over reacting as any residue in the bore probably will disapear after a couple of piston strokes!?
02-13-2018, 11:42 AM #494
yes i think you are worry a bit too much.. it looks pretty nice to me..
might sound daft but if you are worried then what about putting a drop of nail varnish around the area before you start ?
that will come off for sure with acetone. any microscopic buts left will just disappear on first fire up ... just a silly thought..
spybot liked this post
02-13-2018, 12:46 PM #495
