  2. #2612
    Jul 2004
    Connecticut
    Good grab, will have to wait and see on the 22. I guess the Laveycraft is the only 22 V running a 400 at the moment. At least in the states.
  3. #2613
    In the states I believe you are correct. I know of a few down under.
  4. #2614
    is that the Lavey 21xt, I cant see them mentioning a 22 on their site?
  5. #2615
    Jul 2004
    Connecticut
    Correct, that is the model. They have built many of them over the years in various I/O configs. It is longer then they show. Has a twin step 20 degree V.
  6. #2616
    would that have the highest freeboard of any of them?
  7. #2617
    Jul 2004
    Connecticut
    The Laveycraft 21 certainly looks to be deep on the freeboard compared to all 6. It is a substantial boat with a full playpen under the deck.
    Attached Thumbnails Attached Thumbnails Super6SOBsv2.jpg   Lavey21+xtski+stern.jpg   7.jpg
  8. #2618
    Sep 2002
    Parry Sound, On
    Why have a stepped hull when it should be 8' from where the boat touches the water? All the ill handling characteristics of a stepped hull with none of the speed advantage!!
    '08 SRV
    Yamaha 3.1 Phase III
  9. #2619
    Dec 2014
    sunset
    1991 vector/python deep v 1991 7000.00 847-744-0088. without engines. Has tandem aluminum trl.
  10. #2620
    Suffern, NY
    Quote Originally Posted by DoktorC View Post
    That is a very good question???
  11. #2621
    Feb 2003
    Rochester, NY
    One has to remember that one of the things that drove the addition of steps to many v-hulls was the evil handling traits when many of them were "trimmed to the max" to get maximum speed by driving the bow up. Many people just couldn't figure out how to drive a boat with a pad bottom by getting it "up on the pad." (I know Kevin at Progression has had several folks complain that their Progressions didn't go as fast as they thought they should, only to find out that they just didn't know how to drive one up on the pad.)
    So with a stepped hull, one can run with much less trim - and thus the bow runs much lower in the water - and still get maximum speed. Of course this new found speed also came with lots of new handling quirks. (Like getting upside down.) But getting back to step placement, if the bow doesn't need to be way up in the air, more of the bottom is wetted. That would mean a step (or steps) would be further forward.
    Remember, most of us know how to run a pad bottom right at the limit. But running my Progression all the way up on the pad requires me to trim down (quickly) when I approach any kind of wave or wake. Not doing so can lead to getting upside down. But with a stepped bottom, since you're not running with lots of positive trim, you don't have to do as much when approaching a wave or wake. Since most folks don't know how to drive - and manufacturers don't like getting sued (by folks that got upside down or that didn't get the top speed they were expecting) - they decided to try stepped bottoms. (Well, some of them did.)
    1992 Progression 22
    Mercury Racing 250R
  12. Likes powerabout liked this post
  13. #2622
    Suffern, NY
    I think everyone gets that on larger hulls with a lot of drag, but I still think its a great question on the small hulls. A high X and todays props will get your hull riding with very little weted surface area without excessive trim. Looking at the Bernico with that single step way forward just has me very curious as to what the major benefit is. Sutphen uses a relief chine that helps and has no down side effects with handling. To me the question is still a good one "steps on a small boat"??
  14. #2623
    Feb 2003
    Rochester, NY
    Quote Originally Posted by JamesGang View Post
    I hear ya. I struggle with that Bernico step placement too. Apparently it works though.
    1992 Progression 22
    Mercury Racing 250R
  15. #2624
    May 2001
    great south bay
    I think it is originally intended for rough water and low HP, Otherwise only a hinderance.
  16. #2625
    Jul 2004
    Connecticut
    Quote Originally Posted by 2.5-21 View Post
    Assuming you are talking about the Laveycraft here's some info below.
    I know they designed there first 21 hulls in 1994 and then in 1997 they adjusted the bottom to add the "two steps" which I believe is how they build it to this day. I'm not sure if the gentleman who owns the one with the 400 on it currently ever had a 300XS on the boat prior, but it would be interesting to know the speeds if in fact he did.
    Attached Thumbnails Attached Thumbnails LaveyStep21.JPG   LaveyStep21a.JPG   Lavey21+xtski+stern.jpg
Page 175 of 271 FirstFirst ... 75 125 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 225 ... LastLast
