Results 1 to 14 of 14
Thread: removing head dowels from block
07-22-2017, 09:02 AM #1
I had never tried this till today and had zero luck. Any tricks? Thanks
RockTeam Junk
07-22-2017, 09:37 AM #2
a little heat.. a little "taping".. a very good pair of vice grips.. a lotta patience!
rock thanked for this post
07-22-2017, 10:20 AM #3
5000 RPM
- Sep 2014
- Iowa
- 316
- 9
- 31
- 46
- 121
07-22-2017, 11:30 AM #4
5000 RPM
- Jan 2013
- SE MN
- 866
- 44
- 145
- 63
Wrap some 120 sandpaper around the dowel before you grab on with the visegrips. It will help it grip.
Dave Strong liked this post
07-22-2017, 12:50 PM #5
Thanks
Team Junk
07-22-2017, 01:45 PM #6
Junior Member
- Sep 2015
- wilmington,Il
- 22
Goodson tools has a collet style dowel pin puller that works great. On the really stuck ones coat the dowl with a little lapping compound for better traction
07-22-2017, 02:37 PM #7
Got the stubborn little bastards. Patience was an understatement and certainly not my strong suit. Appreciate all the suggestions.
RockTeam Junk
07-22-2017, 03:04 PM #8
Map gas torch works best!enough heat and they come out fairly easy
"Whacker Smacker" #561 IHBA M/E div1 2007& 2006 first looser champion
2007 Sportsmen Driver of the Year
07-22-2017, 04:22 PM #9
Map gas torch is what I used. One came out easy but the other three were hand to hand combat. Thanks again.
RockTeam Junk
07-22-2017, 10:24 PM #10
My son bought a big block of bee's wax for like $6 at the swap meet . he cut it into strips and put them by the saws and vise .
I think the problem is that it's easy to get the dowel pin too hot . I use the wax to cool it down and it also wick's itself in the hole providing lubrication for the pin . If it still wont go , I get it all really hot and put the hose from a nitrous tank aiming at the pin , shrinks and will just about fall out by itself ...
07-22-2017, 11:13 PM #11
5000 RPM
- Sep 2008
- Mass
- 450
- 16
- 39
07-23-2017, 06:53 AM #12
Ive always had success using a Brass rod and tap it in 4 positions and they have always come right out.
07-23-2017, 07:36 AM #13
I like the idea of nitrous. I was thinking about maybe a piece of ice but figured it would melt so fast it would be a waste of time. I used almost all of above ideas except collets. They are like sleeves. Some release easily and some don't. This particular block had blown a head gasket and ran for a while so crank, rods, and sleeve were ruined. Got the sleeve in and was ready to bore when I noticed that during sleeving process another sleeve had turned. Finally got sleeves in proper locations and last night I got it decked. I about took a whippin on this one but looks like it's finally going to work. Thanks again for all the suggestions.
RockTeam Junk
07-23-2017, 08:20 AM #14
Member
- Mar 2004
- Durham Ct
- 30
- 21
- 17
Vise grips / slide hammer. Either weld a coupling nut to the side of pair of vise grips and thread your slide hammer into it or take the adjusting screw out and use a long threaded rod as the bar for the slide hammer.
mid can dowels
By mach1magnum in forum Technical DiscussionReplies: 4Last Post: 11-16-2013, 11:21 AM -
Removing stuck power head (suggestions)
By shadow1986 in forum Technical DiscussionReplies: 41Last Post: 09-10-2013, 02:11 PM -
Mercury Tech: Removing Power Head
By HighVelocity in forum Technical DiscussionReplies: 0Last Post: 02-11-2011, 11:29 AM -
Removing valve seats in aluminum head?
By Euroski in forum Technical DiscussionReplies: 4Last Post: 06-30-2008, 08:20 PM -
Minor block damage from removing head, help!
By Pete Keppler in forum Technical DiscussionReplies: 12Last Post: 04-18-2005, 11:09 AM
