Results 16 to 30 of 30
05-07-2017, 11:02 PM #16
Member
- May 2017
- Yuma arizona
- 65
- 11
- 145
What pitch chopoer
05-07-2017, 11:03 PM #17
Member
- May 2017
- Yuma arizona
- 65
- 11
- 145
05-07-2017, 11:06 PM #18
Vzsuper liked this post
05-08-2017, 07:12 AM #19
My worked chopper was a 28 pitch. Dont remember the rpm's but i would guess 7500.
05-08-2017, 06:53 PM #20
Member
- May 2017
- Yuma arizona
- 65
- 11
- 145
I just got a signature 3 blade 30 p test next weekend ... Ron Hill said if i can spin the cleaver that easy i can run up to a 34 i want to not load the engine bad and get her hot so i hope the 30 is the perfect pitch
05-08-2017, 10:16 PM #21
that's a LOTTA pitch for that little 2.4 bridge,plus the fact that the desert air in Yuma robs power big time...!just saying
"Whacker Smacker" #561 IHBA M/E div1 2007& 2006 first looser champion
2007 Sportsmen Driver of the Year
05-09-2017, 07:53 AM #22
Member
- May 2017
- Yuma arizona
- 65
- 11
- 145
If i was hittin revlimit with a 28 why would the 30 be so dramatic a change that is 112 race fuel and i honestly think this little 2.4 is spittin 260 + on the hp and the hull is a light layup i see all theese allicats turnin that and more or the stv w a 200 spinnin a 34. Now whatcha thank about dat ?
05-09-2017, 01:17 PM #23
Member
- May 2017
- Yuma arizona
- 65
- 11
- 145
Doing some research found polished props have more slip makes sense the 24 chopper was satin and tbe 28 lab finished and a cleaver
05-11-2017, 08:09 AM #24
This similar rig to yours claims 90+. You might PM him and ask for setup tips...
http://www.screamandfly.com/showthre...-JSRE-245-2-5L
05-12-2017, 05:27 PM #25
Scream And Fly VIP
- May 2001
- Hickory NC
- 5,624
- 19
- 270
- 215
- 520
- 5 Post(s)
That 28 cleaver is running over 30% slip as 30% would be 72.8 at 7300. That tells us that either your set up has an issue or a clever is the wrong prop for that boat which I know works better with a round ear propeller. Have you verified tach and speedo are correct? When everything is right slip should be no more than 12 percent.
05-12-2017, 07:05 PM #26
Member
- May 2017
- Yuma arizona
- 65
- 11
- 145
05-13-2017, 09:24 PM #27
Member
- May 2017
- Yuma arizona
- 65
- 11
- 145
So with the 30 drag prop I could only pull to 7000 RPM 80 miles an hour I'm really frustrated and I don't know what else is causing me to not see good numbers that's still like 20% slip I have been talking to a few people can I have some aluminum plates on the bottom of my boat that I believe could be causing too much drag or making the boat not work right it turns on a dime the aluminum Runners are 8th inch thick by about three inches and they run for about three feet from the back of the hole at the transom forward any recommendations or advice would be appreciated I'm about to unbolt these things I should be seeing less slip and more speed
05-13-2017, 10:33 PM #28
05-13-2017, 10:44 PM #29
Member
- May 2017
- Yuma arizona
- 65
- 11
- 145
Ive thrown a dog out and shoked quite a few people when i shut down and turn ill say that ... They're level with the center pad so i assumed they would pack more air and lift more , there has to be no more than 10" or less in the water at full speed, but a gentleman I was talking a gentleman I was talking to you about my setup said he put turning Skaggs on the bottom of his boat and he lost three to six miles per hour.. so I'm losing 20!!
05-13-2017, 10:47 PM #30
Member
- May 2017
- Yuma arizona
- 65
- 11
- 145
The downside to removing them is bolts countersunk into the hull every 6 inches for three feet and then I'm going to have to fill all of them and seems like a p.i.t.a!!
Eliminator Liberty prop help
By Todd98SE in forum Props, Setup, and RiggingReplies: 2Last Post: 04-16-2016, 07:37 AM -
21 Eliminator Daytona prop
By ActivatedSludge in forum Props, Setup, and RiggingReplies: 0Last Post: 08-02-2014, 05:08 PM -
21' eliminator prop heigth?
By stoneman in forum Props, Setup, and RiggingReplies: 2Last Post: 10-04-2005, 03:39 PM -
What prop - 25 Eliminator / 500 EFI
By at100plus in forum Props, Setup, and RiggingReplies: 2Last Post: 05-26-2004, 12:37 PM
