Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 16 to 30 of 49
    May 2009
    Ormond Beach, Florida
    This looks better
    Mark
  2. Likes MeCapnDave, Trimmed Out15 liked this post
  3. #17
    All you need to make that look better is:
  4. Likes whipper liked this post
  5. #18
    May 2009
    Absolutely!!!!
    Mark
  6. #19
    Prince George B.C. Canada
    Sure a sweet looking Talon!! Its got real steeze not sneeze.
  7. #20
    May 2009
    Update - 4/8/2017. RIGGING COMPLETE !!!!!
    Of course, as I was doing all the final checks and running the motor for the first time last weekend the Simrad decided to lose its mind. It's back at Navico and I should have a replacement next week. In the mean time I have Vesselview Mobile which explains why I have a Ram mount rigged to hold my phone.
    Planning on doing the shake down run tomorrow but I'm going to limit myself since the only gauges the mobile app provides is speed, tach, water temp and voltage. And I still need to do the first hour break in running so the motor will stay lower and the trim level or tucked a bit. No top speed runs till I get some seat time.
Name:	Photo Apr 08, 11 31 27 AM.jpg
ID:	372105Click image for larger version.
Name:	Photo Apr 08, 11 30 47 AM.jpg
ID:	372102Click image for larger version.
Name:	Photo Apr 08, 11 30 00 AM.jpg
ID:	372099Click image for larger version.
Name:	Photo Apr 08, 11 35 16 AM.jpg
ID:	372116Click image for larger version.
Name:	Photo Apr 08, 11 33 59 AM.jpg
ID:	372113Click image for larger version.
Name:	Photo Apr 08, 11 33 06 AM.jpg
ID:	372110Click image for larger version.
Name:	Photo Apr 08, 11 31 47 AM.jpg
ID:	372106Click image for larger version.
Name:	Photo Apr 08, 11 30 55 AM.jpg
ID:	372103Click image for larger version.
Name:	Photo Apr 08, 11 30 17 AM.jpg
ID:	372100Click image for larger version.
Name:	Photo Apr 08, 11 35 22 AM.jpg
ID:	372117Click image for larger version.
Name:	Photo Apr 08, 11 34 09 AM.jpg
ID:	372114Click image for larger version.
Name:	Photo Apr 08, 11 33 18 AM.jpg
ID:	372111Click image for larger version.
Name:	Photo Apr 08, 11 31 58 AM.jpg
ID:	372107Click image for larger version.
Name:	Photo Apr 08, 11 31 09 AM.jpg
ID:	372104Click image for larger version.
Name:	Photo Apr 08, 11 30 38 AM.jpg
ID:	372101Click image for larger version.
Name:	Photo Apr 08, 11 36 01 AM.jpg
ID:	372118Click image for larger version.
Name:	Photo Apr 08, 11 32 58 AM.jpg
ID:	372109Click image for larger version.
Name:	Photo Apr 08, 11 34 36 AM.jpg
ID:	372115Click image for larger version.
Name:	Photo Apr 08, 11 33 50 AM.jpg
ID:	372112Click image for larger version.
Name:	Photo Apr 08, 11 32 39 AM.jpg
    Mark
  8. Likes skinnywater liked this post
  9. #21
    Jul 2008
    Mooresville NC
    Awesome Mark! Looking fwd to hearing about the shakedown run!
  10. #22
    Jun 2012
    Indiana
    Very nice!!
  11. #23
    Came out very nice, simple and clean. I like it...
    Jan 2008
    Daytona Beach Florida
    Mark that came out really nice !! Can't wait to see it run !!!
  13. #25
    Beautiful set up!!
  14. #26
    May 2009
    Thanks guys.
    Now I need to decide whether to do a simple cockpit cover or a full cover. Even sitting under a carport the dust and pollen is a problem. The interior will be covered, I just need to decide if that's enough.
    I'm also planning on taking it over to Chris Cruz for some graphics. Not doing a full paint job, just graphics topped with clear. He's already seen pictures and says he has some ideas that can stay within my budget (<$2000) but make it pop so I need to consider protection for that too. Chris is a true artist, I love his work.
    Nothing this elaborate, just an example. I'm staying in the gray palet, not planning on adding any other colors. The one below was done on a base yellow gel coat but I believe he cleared the entire boat, I don't remember for sure.
    Mark
  15. Likes MeCapnDave liked this post
  16. #27
    He has a nice eye with the flow of the hull....can't wait to see what he does with the Talon.
  17. #28
    Feb 2006
    Formerly Central WI/LOTO Currently PHX AZ
    Nice job rigging, and beautiful boat! Your dash and controls are very tasteful.
    Have you weighed it yet? Did Todd give you a target for CG?
    Can't wait to see how it runs. Nice work, nice ride.
    Oh, and you can take the break-in requirement sticker off the cowl now...
    A problem is only a problem when viewed as a problem...
  18. Likes MeCapnDave, Just Tool'in liked this post
  19. #29
    May 2009
    We did weight the boat before it left the factory. Boat, motor, jackplate, fuel tank and interior weighed 1963 lbs., 517 front and 1446 rear.
ID:	372161Click image for larger version.
    I added somewhere between 150 and 200 lbs between the power steering, battery, wiring cables, etc. to maintain the CG I mounted the power steering, oil tank and battery as far forward as possible and balanced the weight with a slight bias toward the port side to counter act my 200 lbs in the drivers seat. With 30 gallons of fuel I'm estimating the total weight to be ~2300 lbs.
    Initial running will be with a 14.5 x 32 Drag 4 built to Todd's specs. Todd is also getting some additional props made by Mercury that I'll test with once it's broken in and I get some seat time.
    And the break in tag has been removed
    Mark
  20. Likes MeCapnDave, HydroSkreamin liked this post
  21. #30
    Feb 2006
    Way cool. Is there any way you can obtain and post the location of each strap to the back of the sponsons at the running surface? I have an Excel spreadsheet that will calculate CG based on your weights and the location of the straps.
    Exciting times! And good job on ugly sticker removal...
  1. Screaming Eagle Boats
    By Spectre Powerboats in forum General Boating Discussion
    Last Post: 03-23-2017, 07:03 AM
  2. Screaming Eagle Boats & Todd Lamb
    By aggiestckl in forum General Boating Discussion
    Last Post: 11-09-2016, 10:31 PM
  3. 2016 Screaming Eagle Talon 22SS
    By checkmate 250 in forum General Boating Discussion
    Last Post: 07-28-2016, 02:12 PM
  4. Hardwear Clets help for Screaming Eagle
    By Bushmen in forum General Boating Discussion
    Last Post: 03-04-2008, 11:17 PM
