Page 2 of 6 FirstFirst 1 2 3 4 5 6 LastLast
Results 16 to 30 of 89
    This thing is going to be cool but I would need to have 3 for sure. Acceleration on a triple engine boat is so addictive and this hull is plenty big to still be balanced. I would love to be in a position to do a project of this caliber "its no cheap deal".
    Jan 2006
    Pompano Beach, FL
    Quote Originally Posted by Rayzor View Post
    You're correct Ron, the running surfaces and tunnel dimensions of the hull remain the same as a standard, non cut-down boat. The only purpose of cutting them down so low is to reduce weight, and aerodynamic drag. I'm personally not a fan of the ultra-low cut down boats, as you still need enough depth in the cockpit and windshield (approximately 40" from the floor to the top of the windscreen) to keep the wind going over the top of the driver/passenger. What ends up happening is the windscreen looks too tall on top of the boat - in my opinion. That's what I don't like about the look of the MTI 34X - the boat is super low profile, with a huge round windshield stuck on top of it. I feel there is a happy medium between the tall standard-deck boats and the ultra cut-down boats. Pete has also built boats with the sides of the hull canted in, which also looked strange to me (not a lot have been built with that feature). But all of that is what makes Skaters so different (and "cooler" imo) than every other boat out there - no two flat deck Skaters are exactly the same! They are truly custom built to each individual buyer's desires.
    Will be interesting to see how tall it ends up. Maybe the guy is short LOL!
    Double
    Rigged
    308 Skater w/400r’s
    Over-Kill
  3. Likes NICE PAIR liked this post
  4. #18
    Random question: What determines the motor centerlines on the sponsons for a cat hull? Is there an industry standard dimension or just the rigging/manufacturer preference? Read a post by Linder that said the prop shaft centerline should be 3 inches in from the inside tunnel but he was using a surface drive set up in that reference. The X-cat motors all seem to vary with their set ups.
  5. #19
    Discovery Bay, CA
    I think it really varies by manufacturer. I know that Pete likes to run the gearcases as tight as possible to the water coming through the tunnel on the 28s - 55" centerline on a 48" tunnel. He says he likes the props to grab the water coming through the tunnel, but the gearcase to be just clear so as to not create any drag. From how close to the outside of the sponsons the motors are mounted on the DW32s, it looks like Doug likes to run them farther toward the outside of the sponson. But that may just look that way because the sponsons are a lot narrower - I've never seen a picture taken from directly behind the gearcase on a DW32.
  6. #20
    Discovery Bay, CA
    Here are pics I took of Matt Rice's new 368. From what Pete said, Grant is on a mission to make this boat very fast........ There will be another 368 being built with 400Rs soon after this one - it won't be near this cut down, more of a standard cut, flat-deck build than this purpose-built boat.
    Attached Thumbnails Attached Thumbnails IMG_4415.JPG   IMG_4416.JPG   IMG_4417.JPG   IMG_4418.JPG   IMG_4419.JPG
  7. Likes noli, tux974, Scream And Fly liked this post
  8. #21
    Discovery Bay, CA
    More pics......
    Attached Thumbnails Attached Thumbnails IMG_4420.JPG   IMG_4421.JPG   IMG_4422.JPG   IMG_4424.JPG
  9. Likes noli, tux974, Scream And Fly liked this post
  10. #22
    Nov 2013
    ca
    Wow, it is really cut low. Would seem OK for a race boat, not so sure it is safe for pleasure boating. One reason would be taking on water over the stern. I guess they will not try to save so much weight that they eliminate bilge pumps, another 8 lbs.
  11. #23
    Quote Originally Posted by noli View Post
    Razor,
    If you're visiting the holy-land, please take some pics of the 36 for us and post here
    Pete is proly concentrating on the cockpit, inside the bilge/transom areas, and the windshield receiver, pics would be great
    also, approximately when she'll be blocked to make ready for paint
    Thank you Razor for giving us these updated pics! Looks great!
  12. Likes tux974 liked this post
  13. #24
    Thanks Razor. I also noticed, I believe, in an XCAT photo that the motors were out further on the DWs.
    Like I stated previously, there is not a lot of transom on that hull for mounting brackets/engines.
  14. #25
    What ever became of this build?
  15. #26
    Discovery Bay, CA
    I'm pretty certain it's at Grant's by now for rigging. It was in the paint booth to be sprayed when I was at the factory last on 11/07.
  16. Likes noli liked this post
  17. #27
    Jan 2006
    Pompano Beach, FL
    Dale, Really this is Skater we are talking about LOL!!!!!
    Hope your boat gets done faster than some.......
    Double
    Rigged
    308 Skater w/400r’s
    Over-Kill
  18. Likes NICE PAIR liked this post
  19. #28
    Discovery Bay, CA
    Quote Originally Posted by Double Rigged View Post
    Gheez Ron, if Skater can't get it painted and out the door in two months after this pic was taken, something's wrong!
  20. Likes NICE PAIR liked this post
  21. #29
    Jan 2006
    Pompano Beach, FL
    Update, Boat is still at Skater and Grant was there today with Pete per my intel!
    Double
    Rigged
    308 Skater w/400r’s
    Over-Kill
  22. Likes NICE PAIR liked this post
  23. #30
    Discovery Bay, CA
    I just heard that it's still there! Steve's 318 will be the representative for the Skater outboard boats again at the Miami show now. I heard the reason it's still there is because of a rigging issue with the ROS motors.
  24. Likes NICE PAIR liked this post
  1. WANTED twin 2.5 280 with 15" mids
    By whiteboy in forum Engines Wanted
    Last Post: 07-03-2016, 12:21 PM
  2. Twin 2013 300XS's 20" mids 1.63 Sportmasters
    By skate in forum Outboard Engines
    Last Post: 06-24-2016, 12:22 AM
  3. Photos: 28 Skater - Twin 15" 300X's - Offshore Race Boat
    By Point Five in forum General Boating Discussion
    Last Post: 03-27-2016, 03:00 PM
