Results 16 to 30 of 42
01-10-2017, 11:06 AM #16
They are out there. Not that hard to find. JMO
Michael J Giesler liked this post
01-10-2017, 11:18 AM #17
I'm sure you'll do research, and find that the 260 280 requires re-ringing, freshening up A LOT sooner than other motors. BUT do haul the mail!!
James
01-10-2017, 01:14 PM #18
5000 RPM
- Sep 2009
- Miami
- 358
With a 260 or 280, what is the average ring lifespan? Is this every 25 hours or 100 or so hours between re-ringing.
Tom
01-10-2017, 02:21 PM #19
5000 RPM
- Aug 2014
- Central WI
- 107
- 21
01-10-2017, 03:36 PM #20
7000 RPM
- Feb 2005
- seattle
- 2,654
- 17
- 33
just for the record.
i've had serios head gasket with pre 1999 head gasket motors. it had 5 motor blow up. i now prefer the newer o-ring heads.
you can get Jay to modify 2.5 gaskets to o-rings.
01-10-2017, 05:17 PM #21
01-10-2017, 05:19 PM #22
you have other problems, it's not the design of the gasket. I've never had an engine failure that was related to the design of the head gasket and sealing surface.
You are either using unsquare heads and or block deck, using crap gaskets or not sequencing and forcing the heads properly.
I have 2.0's,2.4's and 2.5's currently on boats i own none of them have ever failed to this reason. And I've blown up some sh$t over the years.
Markus thanked for this post
01-10-2017, 05:51 PM #23
01-10-2017, 05:57 PM #24
AND, as far as a 260 and re-ringing....I bought a brand new one in 1995 and ran it on a fishing boat until 2015 without touching it!!!!
Grant you it wasn't ran at 7500rpm constantly like most racing applications but Lord know how many hours were on it when I did a complete overhaul inc. replated cyls!!!!
This time around unless I start showing a bad leakdown it will get rings at 200 hours even though most recommend 100!
Slimm liked this post
01-10-2017, 09:05 PM #25
5000 RPM
- Aug 2014
- Central WI
- 107
- 21
01-10-2017, 09:19 PM #26
Look it up on you tube
01-10-2017, 09:31 PM #27
5000 RPM
- Aug 2014
- Central WI
- 107
- 21
01-10-2017, 10:14 PM #28
01-10-2017, 11:40 PM #29
That's it thanks buzzin
01-11-2017, 12:28 AM #30
5000 RPM
- Aug 2014
- Central WI
- 107
- 21
changing from 25" to 20 " on 84 merc 150..whats involved?
By john b in forum Technical DiscussionReplies: 5Last Post: 01-11-2006, 08:09 PM -
Do all 2.5 mercs have "caged" rod and main bearings?
By O/B Dude in forum Technical DiscussionReplies: 6Last Post: 08-19-2003, 01:04 AM
