Results 1 to 14 of 14
    Mar 2004
    Okc OK
    Looking for a part #
    I need some help finding a part. This is a single ram trim, 2.something mid (now OS). I need to replace the pin that goes through the brackets and the top part of hydraulic trim ram.
    Any input would be appreciated.
    Todd Stone
    Oct 2010
    Harrisburg,Pa
    Mar 2004
    Okc OK
    That was helpful, but all the places I'm checking show the part as NLA. It's part number 85024. Anybody know anybody that might have one for sale?
    Todd Stone
    Oct 2010
    Harrisburg,Pa
    Check at Seaway marine,huge new and used parts dealer,they buy up old stock.
    http://www.seawaymarine.com/
    Mar 2004
    Okc OK
    Shows NLA there as well. Thanks for the site though.
    Todd Stone
    Oct 2010
    Harrisburg,Pa
    Call them to see if they have a used one. Your done looking for new, you are looking for used now.
    Oct 2010
    Harrisburg,Pa
    After that google mercury dealers and look for one in stock,then google outboard recycling,junk yds,bone yds etc. Good luck!
    Sep 2012
    Pennsylvania
    Todd ,
    PM sent .
    Steve
    Somebody at Merc should get kicked right square in the nuts for designing that mess... I have two single ram trim units here with the pins broken in half.
    "Gee Gomer, let's see how bad we can make this... drill a hole in the shaft and then drive a wedge into the hole, what could go wrong?"
    Have one made.
    Yeah, I can make a better one but the broken pin has the holes all beat up so it's more than just making a pin now.
  12. #12
    Sep 2012
    Pennsylvania
    You could make the hole blind and thread it for bolt or grub screw . Stronger than a through hole .
  13. #13
    Yes, I don't use the trim gauge or trailer/tilt switch so I don't need the slots on the ends for that; which also means the pin doesn't have to be anchored to keep it from turning... which means I don't even need a hole in it.
    But, like I said, the broken pin messed up the yolk on the top of the trim ram, too.
  14. #14
    Time for a bushing.
  15. Likes Steve-S liked this post
  1. Yamaha Tech: Mystery Yamaha electrical part (part of trim wiring harness)
    By Mr. Demeanor in forum Technical Discussion
    Last Post: 09-16-2013, 08:32 PM
  2. How to ID part by a part number...Rickracer?TTriton?
    By LakeRacer99 in forum General Boating Discussion
    Last Post: 12-25-2004, 11:07 PM
  3. Replies: 6
    Last Post: 02-14-2002, 07:27 AM
