Results 1 to 4 of 4
Thread: Gear ratio for a 1976 1500 L6
01-18-2006, 05:46 AM #1
Whats the gear ratio for a stock 76 1500 l6.Thanks
Bob
01-18-2006, 06:20 AM #2
2.0:1
Bruster's Mercury solid motor mounts, details here:
http://www.powercatboat.com/Bruster/Bruster.htmlI'm been living in fast forward, now I need to rewind real slow....
01-18-2006, 07:14 AM #3
Every 1500 inline ever made came from the factory with 2:1 gear ratio. The 71 1150/1350 was the last of the 1.78:1's in inline 6's. The 4 cyl 850's in the 70's would've had 2.3:1 and looked identical externally as far as the gearcase goes. I've run across at least 1 1500 that somebody stuck a 4 cyl gearcase on, so it's best to check. The 1.78's from the early 70's were noticeably blunter on front than a 76 gearcase would be. I've run across a couple of those that'd been switched onto later 1500's also. Lots of stuff gets switched around on old motors in 30 years.
01-18-2006, 09:22 AM #4
Thanks.
Bob
