Results 16 to 30 of 44
Thread: Diesel Power for the Ford guys
12-24-2005, 03:19 PM #16Originally Posted by 150aintenuff
Only late producton 95 was turbo.
00 and up with chip can go to 350hp with 600ft pounds of torque easy!!!
And this bairly pulls with the new Cummins B engines? ( BS B engine does not have a chance)
The B engine has been in productin from the early 1980's they were first built in the Charleston SC plant. I was there! It has been in motorhomes and mid size production trucks for years.
And you ask anyone who has one, they get passed with a load, and they also have to stop for fuel more often. I know your gona argue this to death. But it's a fact! I know it is! And so do you.
The truck pull, lets see! Dodge had wieght in the rear? And traction?
That was the differance!
More have changed from Dodge to Ford than any other manufacture!
And I work for GM!
Al“The bitterness of poor quality & service remains long after the sweetness of low price is forgotten”
12-24-2005, 03:24 PM #17
12-24-2005, 03:41 PM #18
Al I took the HP specs directly from the ford motorcompany archives... 275 didnt come out till 03 Intercoolers came with the new body style change 99+ 98s were still the old style... 98.5 is actually what the first new style trucks are billed under.. they didnt actually build any f250/f350s in 98 at all.. the old style unsold 97's were redubd 98's and the new production run wer dubbed 99's that came out in july of 1998
12-24-2005, 03:45 PM #19Originally Posted by 150aintenuff
I know they were building both for a few months.
Was not sure what was what, but correct, new style was the intercooled engine.“The bitterness of poor quality & service remains long after the sweetness of low price is forgotten”
12-24-2005, 03:46 PM #20
ALso the new dodge 600 is dubbed the B model.. that is what i was refering to.. Alsi I have a 1996 that has been built up as far as I would want to stress the older motors.. and on the 1997 and older (old body style) an intercoller actually didnt help HP and torque all it does is lower EGTand my truck actually lost torque when I installed it.. so I removed it.. i have consistant 1100* after turbo and 1300 preturbo EGTs and can sustain those temps continously all day long.. with the inter cooler i was at 950 post turbo and blowing smoke.. at 1000 it clears up and doesnt smoke..
12-24-2005, 04:09 PM #21
How many of you guy have ever pulled on the pavement in a tug-o-war,its complety different than pulling a sled in dirt ,all this hp dont mean squat.
20 SHADOW 300+ V8
12-24-2005, 04:41 PM #22
airboater i guess you mean its all about traction/weight right? i know that if you put a 22re toyota 4cyl (Geared lower then you can imagine) in a ford f250 4x4 with full payload and hooked it up to that dodge you could sit there with the brakes on untill the dodge starts spinning then you would be able to pull the dodge where ever you want correct?
kevin (ok maybe the 2.2 re was a slight exxageration )
12-24-2005, 04:57 PM #23Originally Posted by baja200merk20 SHADOW 300+ V8
12-24-2005, 05:00 PM #24
So true so very true!!!!
traction! traction! traction!“The bitterness of poor quality & service remains long after the sweetness of low price is forgotten”
12-24-2005, 05:09 PM #25
12-24-2005, 05:57 PM #26
only pull off i was in cost both of us drivelines and neither of us moved an inch..
12-29-2005, 09:01 PM #27
12-29-2005, 10:41 PM #28Screaming And Flying!
- Sep 2003
- shreveport,la
- 5,497
- 18
- 24
- 212
How much HP
A friggin' heap...
Kevin Kiser
12-29-2005, 11:31 PM #29
yea something is wrong
never will you see a cummings out power a 7.3 or the new 6.0 powerstroke thats not possible i agree that the 4 wheel drive didnt apear to be working in the ford also the dodge looked to be a 3/4 or 1 ton and the ford 1/2 the suspension between those 2 can make all the difference in a high stress situation and once again im not convinced the ford was in 4 wheel drive.the simple fact is the 7.3 powerstroke was unmatched and the 6.0 is getting there with upgrades im not totaly biess to fords but there is no arguing the powerstrokes.
12-30-2005, 07:30 PM #30
bigbore some one on here was sayin there are rumors of a 6.4L powerstroke for 07 (bored out 6.0) with twin turbos! the 600ft lb cummins wont stand a chance...
i did the glow plugs in dads truck today (97 psd 5spd) the truck will not start under 50*... i hopfully fixed that problem by doing glow plugs and the relay...
wut kind of power are you guys getting outta them turbo diesels out there lets see some numbers/burnouts what ever ya got
kevin
