Results 1 to 15 of 22
    Jul 2005
    Norway
    Painting parts on the powerhead?
    While rebuilding the engine, I thought I would pay some attention to detail on it as well, so I was just wondering if "regular" spraycan-paint will hold? It`s the heat I`m thinking of here...So will it?
    Or do I need to powdercoat it, or use heat-resistant paint?
    The powdercoaters around here only seem to have only dull and regular colors....
    The parts I`m thinking of is the heads, startercover, brakets to the starter the holder/brakett the ECU sits on and so on...And yeah, the outer part of the reed-block..The part that you see when the powerhead is back togheter.(I`m also thinking of buying a spacer here..So I haven`t really decided if I`m going to paint the reed-block.
    Any tips appreciated!
    I have gotten alot of the parts glassbeaded to, so I`m thinking I should just clear-coat it to keep the engine "clean".
    It`s a EFi 2.5 260 by the way..
    I slapped on a couple of pics to show the "style" I want on the engine..And yes I know the first engine has Simon heads(Anodized), but the second one has the original heads painted, as you see in the picture...just ain`t sure if it`s powdercoating....
    Hydrolift T-20, Merc XR2 200+
    MN
    Not sure about the paint, but the blow-me-away hardware is pretty neat.
    Nov 2003
    Auckland NZ
    The second motor belongs to a guy named Grant, he's on this board as
    G ROWE, send him a PM and ask him what we painted his motor with.
    Jul 2005
    Norway
    I thought of that too, but....
    It dosen`t seem that that engine has been running for very long yet, so I was kinda hoping that there was somebody else here that knew if the "regular"-paint would last on the heads...Or if it would flake right of due to the heat.
    Mar 2003
    Ft Lauderdale Fl
    i paint motors all the time with regular automovive paint. If your motor is hot enough to flake paint the paint is the last of your worries
    Aquarius Inflatable Yamaha 70 EFI
    24 Skater Twin 3.0 300x copies 113mph so far
    954-861-1611
    Jul 2005
    Norway
    Started painting today...
    Started today using the automotive paint...And I`m quite pleased with the result..
    (And no, my engine runs cooool...Not as hot so the paint would flake, but I was not sure if automotive paint would stick to the heads during it`s regular running temp.)
    Jul 2005
    Norway
    And let`s not forget the other parts as well...
    Here they are...
    May 2005
    Auckland, New Zealand
    Quote Originally Posted by Hydro-T20
    Ha Ha, you would be right about it not running for long yet ,
    I have a couple of 280,s painted aswell with no flaking after hours of use.
    The paint i used is a dulux metalic gloss enamel, hot soapy washed the parts and then a good does of wax and grease remover.
    Will post some pics if you want, looks good so long as you leave some parts unpainted to break it up a little.
    G
    Speed dosent hurt, its the sudden stop!!
    Jul 2005
    Norway
    Hey G Rowe!
    Quote Originally Posted by G Rowe
    G
    I had the heads glassbeaded, then used primer and the metallic blue paint you see in the pics+two layers of clear...Turned out good.
    It looks like alot of parts now, but it`s only going to be "details" on the engine, don`t want to over do it as you mentioned...Think it will turn out great by the looks of things..
    And yeah, please post the pics!
    May 2002
    long island,N.Y.
    how about a few pics of that turbocharged merc?
    May 2005
    painted 280 pics
    heres one of them in the process of changing mids
  12. #12
    May 2005
    Quote Originally Posted by viper15
    I have a thread open with some pics, search twin turbo outboard.
    In the process of making some mods
  13. #13
    Jul 2005
    Norway
    i have em...
    And here they are.. There are 10-20 more but, can`t post all of em here..
  14. #14
    Jan 2006
    Ontario, Canada
    Those are some wild mods!
    Walking a fine line, and enjoying the view
  15. #15
    Feb 2005
    Muskoka Canada
    The heads are not Simons, They are Galen Burdens, Simons are a copy.
    RT
    2023 TUFF 25
