    Feb 2005
    Ohio
    Spare stuff .....
    Quote Originally Posted by Lake X Kid View Post
    30 factory supported boats, is one of the numbers, that catches my eye. with the side doors open ......
    How many extra powerheads and lower units, would you bring to a race, to support such a large assemblage?
    Ya gotta' remember, 30 factory supported boats was for the hypothetical race. In the real world, for a race of this stature, we probably would have had no less than 12 and as many as 20 boats to look after. We would have packed 10/12 powerheads into 'Day Tripper' and about 20 speedmasters. Probably would have added a half dozen of the McI speedmasters ..... just in case.
    That's 'Day Tripper' at our Havasu headquarters, the big truck with the side doors open, silver box, white cab .....
Name:	1970 Havasu Rented Home.jpg
  2. Likes Mark75H, Lake X Kid liked this post
  3. #4487
    Quote Originally Posted by willabee View Post
    Don't forget the BP Gearcases!!!---On Sunday afternoon---November 1969---it was impossible to walk through the yard--
  4. Likes Mark75H liked this post
  5. #4488
    Feb 2005
    Ohio
    BP gearcases .....
    Quote Originally Posted by GENE LANHAM View Post
    Don't Forget? ..... Anyone that ever worked with those heavy, leaky, shaft breaking, gear crunching, stinky lower units will never forget them! When you tried to check the lube and it sprayed that green slop all over your clothes, you smelled worse than dead fish for days. I remember one exploding and getting that stuff in my hair. It was a hot day and as I perspired, that green goop kept running down my face ..... was one of the most miserable afternoons I ever spent at a race site.
    1969 Havasu ..... don't remember how many, but we sure had a bunch of them in that race. There were triples, twins and singles all running those things. We took a big number of new spares and brought home an equal number of busted up units. I don't remember if those were the new SR units.
    From Powerboat ..... mentions a couple of the triple Jones boats coming in for lower unit repair .....
Name:	PB HAV 69.jpg
  6. #4489
    ...internal overpressuring was one of their issues. the two opposed rear propshaft seals could'nt handle it, so out went some oil, and in came some water, all the time. venting the case somehow would have taken care of that. it had a couple other issues. so many things we know better today, could improve that design.
  7. Likes Mark75H liked this post
  8. #4490
    [QUOTE=willabee;3226161]Don't Forget? ....
    1969 Havasu ..... don't remember how many, but we sure had a bunch of them in that race. There were triples, twins and singles all runningthe SR those things. We took a big number of new spares and brought home an equal number of busted up units. I don't remember if those were the new SR units.
    QUOTE]
    All the SUPER BP’s were built with the SR. A lot of the BP’s had been modified—-
    (WHAT DOES sr STAND FOR?)
  9. #4491
    Feb 2005
    Ohio
    Sr .....
    Quote Originally Posted by gene lanham View Post
    .... all the super bp’s were built with the sr. A lot of the bp’s had been modified—-
    (what does sr stand for?)
    SR = Steady Rest ..... an additional bearing to support the propshaft (thought I forgot that didn't you ).....
  10. Likes GENE LANHAM liked this post
  11. #4492
  12. Thanks GENE LANHAM thanked for this post
    Likes Mugs914 liked this post
  13. #4493
    South Florida
    11 Post(s)
    I had never looked at a cutaway of one of those units before. It looks like a left hand Super Speedmaster with a very fragile looking reverse gear and pinion added in the back. As I recall the left hand Speedmasters had a very high failure rate. That reverse gear doesn't look strong enough to survive any real force. What could possibly go wrong? But my experience was only with production type gear cases so what do I know?
  14. #4494
    Ten races----Four engines----Zero failures----
    But----
Name:	444 to Nassau 69 001.jpg
  15. Likes Mark75H, GrewuponLakeX liked this post
  16. #4495
    Dec 2001
    That cutaway is the one I did......Got a cracked case from MK75 H..... milled it for display ….The interesting thing about that case was the middle shaft was missing the roller bearing.....You can see where the shaft was rubbing the case. All 3 gears are turning in Forward or R......Loaded for that rotation..... When in reverse.... the loading is Wrong and most of the load is on one pinion..... The prop shaft was kinda thin and let the gears walk..... JMO.....
  17. Likes GENE LANHAM, Lake X Kid liked this post
  18. #4496
    ...BUT...you went through them after every race...
  19. Thanks GENE LANHAM thanked for this post
  20. #4497
    ...Later, when the T1's started being used on a few of the same offshore boats, the BP's actually did better than the alternative, which was a locked standard gearcase, which some were using. Still needed the spares though, of either gearcase. Did'nt shift the BP's either, which helped a lot. The need for full size propellers, was the issue, in offshore.
  21. #4498
    Don't Forget? ..
    69 Havasu---the first time most of us had ever seen the ADAPTER----
    And then brought back an old issue--LHSSMClick image for larger version.
Name:	Capture Rudy Ramos.PNG
  22. Likes Mark75H liked this post
  23. #4499
    How about a half dozen MC1's?
    I don't recall---an OFFSHORE boat with a T-1??Click image for larger version.
Name:	Rabe  Fernandez six.PNG
  24. #4500
    ...hard to tell from this photo, but juan ran quad T1's & BP gearcases on his magnum with spares of everything...
Page 300 of 348 FirstFirst ... 200 250 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 ... LastLast
