Page 20 of 348 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 70 120 ... LastLast
Results 286 to 300 of 5210
  1. #286
    Feb 2005
    Ohio
    Quote Originally Posted by peterse90 View Post
    Not sure if this attached picture and caption (if you can read it?) has appeared before.It's about how this radically new "pickle-forked" boat was secretly brought to Dayton, Ohio on June 17, 1972.Was this the first sighting of a pickle-forked boat in North America?Please elaborate on this secret mission.
    The picture is on both posts #105 & #188 with some background info about it before it came here (I have the black & white picture, no caption). The secret stuff the writer is refering to is how the boat was covered at the nose and the rear until it was in the water and then immediately covered before it was pulled out again. Merc made a bit of a spectacle out of trying to hide it (that's always good for some additional PR.....act like you don't want it).
    I think Stylecraft or Powercat might be called the 1st pickle fork in the OPC ranks, but to me, that's a bit of a stretch (you posted a photo of Harold Eis in his Salty Cat Stylecraft on the "Hot Multi's" thread and that was from 1964). I think they had more of a "relief" in the nose than they did pickle fork sponsons. Olegator could probably tell us when McCall started building his pickle fork. The 1st full pickle fork I recall was the 18' twin Ron Jones that Bill Cooper won the Long Beach Invitational with in 1968. Jones was building pickle forks for the drag racing people before these boats made the scene.
    Here is Eis, Cooper and Gary Ferguson .....
    Attached Thumbnails Attached Thumbnails Power Boat Mag 064.jpg   PB68&69 026.jpg   Power Boat Mag 013.jpg
  2. #287
    Phoenix AZ
    Does anyone know anything about this Molinari #95 called Hales Comet ?? Bad picture, but the only one I have.
  3. #288
    Oct 2005
    Re Willabee.........Speed records. Yep you are absolutely correct: Dick actually had Bill Sirois take some runs too in my "Sprint" Miles boat. I forget what his time was but mine was a tad over 113 MPH. Pretty slick for a Miles and it didn't even "snap-over"!
    I think I still may have the jacket we were given, but as we all know it likely has the "closet shrinking" problem so it likely is too small.
  4. #289
    Feb 2005
    Ohio
    Quote Originally Posted by Old fiberglass View Post
    Nothing rings a bell for me, where/when was the picture taken? Are you sure it's a Molinari.....something looks wrong or different.
  5. #290
    Phoenix AZ
    Willabee I was told it was a Molinari, but I don't know much about them. I'll double check the info. I believe the picture was taken in the early 70's and had a Twister on it.
  6. #291
    I'm sure it is a Molinari ... from the era of the "banana" bottom I think. Comments from Mr. T2X would be helpful
  7. #292
    Keswick, Ontario
    8 Post(s)
    Quote Originally Posted by willabee View Post
    The strong box looks higher than most Molinaris and the cockpit looks much smaller than most of the old rocker-bottom Moly's...could it be a Del Craft???
  8. #293
    May 2002
    Granite Quarry, NC
    I'm going to guess..and this is just that,.... a guess..... that the boat is a Kitson. Just about everybody was popping Glastron Molinari's back then...and Kenny was probably the most prolific...building at one point, one boat per day. He had both Miles and Molinari hull molds in the early 70's.
    T2x
    20 Foot Switzer Wing 2 X S3000 (Dust'n the Wind II)
    !6 foot Wood Eltro Vee (2X Merc 1500's) (Dust'n the Wind IV)
    15 foot Powercat 15C (2 X Merc 1500) (Dust'n the Wind III)
    (Single engine boats are lacking something)
    15’ Wooden Switzer Shooting Star...
    16 foot Lee Craft Merc S 3000-(Gold Dust II)
    (The exception proves the rule)
    Obsolete and Proud of it
  9. #294
    Feb 2005
    Ohio
    Quote Originally Posted by T2x View Post
    I'm going to guess..and this is just that,.... a guess..... that the boat is a Kitson. Just about everybody was popping Glastron Molinari's back then...and Kenny was probably the most prolific...building at one point, one boat per day. He had both Miles and Molinari hull molds in the early 70's.....T2x
    I don't know, there is something about that picture that makes me think it is not a Molinari or a glass copy of one. Do you see something that tells you it is a glass boat?
    I have not seen enough Del Crafts to comment and I'm not sure where to find a photo of one. Weren't they run in "SJ" rather than "U" or "S" as this would be if it in fact has a Twister bolted to the tail?
    That style windshield, what appears to be the plastic sheet to keep water out around the fuel cap and the "single" fuel filler .....who in the states used them around 1970? Something about the blend lines .....early Cougar?
  10. #295
    IL
    This is an old Dell Craft SJJ boat.
    Mark
  11. #296
    May 2002
    Granite Quarry, NC
    I'm thinking it's a glass hull because it has a rub rail.......
    As far as The Cougar question.....every Cougar I ever saw had square cowlings.
    T2x
  12. #297
    Cooper City, Fl
    olegator
    Where ya been? Missed you at the last few old motors and folks meets..
    Butch & Treasure
  13. #298
    Feb 2005
    Ohio
    Quote Originally Posted by MN4V View Post
    Mark
    Thanks, do you have it from the other end?
  14. #299
    Feb 2005
    Ohio
    Quote Originally Posted by OLEGATOR View Post
    To The Noa Nationals In 1969. I Have A Picklefork Built In 1963. It Was Made By Bill Critchfield. Rodney Thompson Built The Molds A Couple Years Earlier By Cutting Down A Jav Cat.
    1969, I would have guessed earlier.....You have any thoughts on that #95 hull ?
    Trying to see how the #95 and the old 18' rocker Molinari's (Mark 75H's "banana" )compare.....The Glastron/Molinari's were made from the design of the #177, #251 and #457 18'ers that came immediately after the #S36 which is shown in the center. So if it is a glass boat copied from a Molinari, it would have to look like the three I mentioned on the far right. If it is a wood Molinari, then the one in the center is it's mate...........Damn it Old fiberglass, why did you have to bring this up?
    I can't tell, what do you guys think?
    Attached Thumbnails Attached Thumbnails Molinari95.jpg   Power Boat Mag 103.jpg   Power%20Boat%20Mag%20037.jpg
  15. #300
    May 2002
    Granite Quarry, NC
    Looks like the Checkmate....... or Kitson...or Baja.....or Glastron Molinari painted black.
    I'm still guessing Kitson.
    T2x
