Results 1 to 2 of 2
Thread: throttle/shifter linkage
11-07-2005, 08:51 PM #15000 RPM
- Oct 2005
- 187
i got a prob with the linkage going from controls to engine. i jsut got new inteior in boat so tehy had to take stick off of control box to get the vinyl side panel off,and wehn we got boat back it had stick misaligned, linkage scrwe up totaly. i got the shfiter to where neutral is in correct position, but the engine is suppsoed to stay in neutral if u pull shifter out and then push throttle forwards. but i can stil see the linkage on the engine shifting while i give the engine fuel even after i pull the stick away from the control box. the box is self contained and has teh two wires from it to the engine and then teh stick comes out of it on the side. i checked the linkage while teh engine was not turned on so i am not sure how that would affect it, but i no it initialy did not work when we tried to put boat in water.
11-07-2005, 09:04 PM #25000 RPM
- Oct 2005
- 187
does anyone have an illustration or schematic of the controls?
