Results 1 to 2 of 2
Thread: help with stator
10-23-2005, 11:35 AM #1
help with stator
running 2.4 bridgeports,and can't keep the batteries charged. Also runs like dog doo !!!!
I'm wondering is there a stator that puts out more AMPS or VOLTS than the stock version???
I don't have a stereo or any other equip. other than a bilge pump in the boat!!!
Have twins ,so I want to do it right the first time!!!!
Should I replace the voltage reg. at the same time????
The season is over in this area ,but want to have it figured out before spring!!!!old rigs vegas xt 200 xri ----- eliminator daytona 23 twin bridgeport efi
newest rig 28 APACHE BRAVE twin 502 Mercs
10-24-2005, 11:07 AM #2
Simon Motorsports
Simon motorsports makes and alternator kit that puts out 50 amps I believe. You could also go to a 40 amp system but depending on the kind of RPM's you turn, your motors might not like the heavier flywheels. They could be lightened I believe. But with good batteries and a properly working sytem, your 16 amp system should be sufficient. Low voltage will richen up your ECU's and make it run like dodoo.
