Results 1 to 2 of 2
    Nov 2001
    Orange County, CA
    Parker / Bluewater 300 Enduro
    Ok, the 300 mile races at Parker is right around the corner. It's open to any open cockpit boat 22' and under.
    Who's going and what are ya running?
    We are Team Short Bus Racing and were are running a 1975 vintage Spectra 20' v drive in division #2.
    I know alot of you guys would fit right in so if ya want it's still not to late to get in on the fun.
    Here is a copy - paste of the division breakdowns. I got this info from www.********************
    Div. #1. Small outboard V-Bottom & Tunnels (min. length 14’-max length 17’11”) SLT's of 13' or more. Engines shall be of the shifter type and shall have a working forward neutral-reverse gear-case.
    Cracker boxes, Jersey Speed Skiffs, Tri-hulls and SLT's may be raced in this division..
    Div. #2. Inboard V-bottoms/Production I/O’s,510 cu.in. max, 18’ to 22’-nostalgia Inboard flat-bottoms-jet boats (must be equipped with a rudder that extends at least 4 inches below the jet nozzle and has a minimum surface area of 16 inches. Jet-a-vator type adjustible nozzles may be used but must remain in the down position at all times when in pit row and shall remain in the down position until safely back on the race course. All engines in DIVISION 2 must be naturally aspirated.
    Div. #3. Single engine outboards with a standard type fishing "club foot" (water pick-up above the prop shaft) lower units and single ALPHA DRIVE ONLY equipped production engine inboard/outboards. (No turbochargers or superchargers, no nose cones, no Speedmasters on any lower unit in Div #3). It is felt that these boats will not be able to sustain speeds of over 75 mph and the intent is to open the rules enough to entice river racers who have wanted to race but never had racing type equipment. Div #3 was previously restricted to bass boats, but is now open to other boats of similar speed ability.
    Div # 4. V-BOTTOM PRODUCTION OUTBOARD: must comply with current ski race rules. Prop shaft must be no higher than the bottom/pad of the boat, as measured from center of the prop-shaft.
    Div. #5. MODIFIED V BOTTOM PRODUCTION OUTBOARD: (prop-shaft must be run a minimum of 2 inches below the bottom of the boat/pad, measured from center of shaft).
    Divl. #6. PRODUCTION INBOARDS, I/O’S, AND OUTBOARDS (single & multi): Minimum length of 18’ and maximum length of 22’6”. Boats in this class may use supercharged or turbo charged engines.
    Nov 2001
    Orange County, CA
    so far this is who has sacked up:
    DIVISION BOAT # TYPE OWNER DRIVER CO DRIVE CO DRIVER PIT #
    Div. 1 P24ThornhillCBoxGreg FalconerJerry RossAmy Ross 13
    Div. 1 48 Sterling Jon Roth John Lane Jon Roth 19
    Div. 2 24 Rayson Ted Kolby Ted Kolby Rod Zapf Joe Cucci 1
    Div. 2 305Rayson Ben Marrone Paul GricharPhil LukensBen Marrone 4
    Div. 2 CJ40 Advantage Don Moyle Don Moyle 9
    Div. 2 ET96 Doidge Ken Knudson Ken Knudson 14
    Div. 2 2 Dana Perf. Chris LloydChris/Tyson LloydTony Scarlata 15
    Div. 2 98 Tarus John Bonnici John BonniciKent Santos 11
    Div. 2 12 Rogers Hau Nguyen Frank Marrone Jr.Hau NguyenJohn Raptis20
    Div. 2 ?Saguaro Rich Enoch Rich Enoch Robert Taylor21
    Div. 2 71 Spectra Bruce Penny Bruce Penny 22
    Div. 2 CJ 72 Sanger Jim Rich Jim RichJason BeckerBill Kean 23
    Div. 2 810Howard Steve Rankin Steve Rankin 24
    Div. 3 284 Allison John Sherlock John SherlockDaren Goehring5
    Div. 4 53 STV Greg Foster Greg FosterTim Herbst 16
    Div. 4 124 Bernico Ryan Pryor Ryan PryorJasson Miller 18
    Div. 5 9 Baker Ron Hill Ron Hill Chad Hill Pat Bowman 2
    Div. 5 819Stoker Al James Bill James Al James 3
    Div. 5 22Stoker Daneille Nelson Mark Halyak Bill Reiter 10
    Div. 6 47Rayson Bob Devine Rob Devine Bob Devine6
    Div. 6 19 Rayson Onlee Forbis Paul Fitzgerald Jim Louis 7
    Div. 6 17Sanger Larry Dalhoff Larry Dalhoff 8
    Div. 6 790 Rayson Lanse Haselrig Lanse Haselrig 12
    Div. 6 25 21' Blaze Nordic Boats Lonnie FluentScott Pelaton Aaron Fluent 17
