Results 1 to 13 of 13
Thread: Converting 25'' mid to 20''
09-29-2005, 06:12 PM #1
I guess the big question is,will a 20'' center bolt to a 25'' swivel bracket?
What else should i take into consideration?
Thanks Stoney!
09-29-2005, 08:59 PM #2Screaming And Flying!
- Dec 2001
- 9,502
- 269
- 191
- 1975
Parts
You can change it on the boat. Just unbolt the 4 long studs and the 3 bolts in the back. Pop the clip off the swivel pin and the exhaust housing will drop off if the swivel splines are not rusted tight. You can push the rolled pin out of the upper shift shaft and pull the shaft as to change the shaft length. Drive shaft to be cut wit hacksaw. Just kidding.
09-29-2005, 09:19 PM #3
Thanks Dave!
I thought the housings were exchangable,just wanted to check.I'll leave the drive shaft to a professional!I'am looking at picking up an older 25'' moter to tinker with and would want to change with a 20'' offshore.
Thanks Stoney!
09-29-2005, 10:00 PM #45000 RPM
- Aug 2003
- Onset, MA
- 347
- 7
I have a similar question . . . Can you bolt a 2.4L powerhead onto a 2.0L mid section?
I have a 1981 merc 225 with a failing trim and tilt unit . . .(leaky cylinder seal, cracked trim lines and a leaky pump) also the bottom of the steering arm tube (part with the clip) has almost disintegrated (rotted to hell).
My friend just blew the powerhead on his 150 XR-2 . . .he's willing to sell me the mid-section and lowerunit. The powerhead on the 225 purrs . . . Before I get all excited . . . I'm hoping that someone can tell me if the early 2.4L powerhead will bolt up to the 150 XR-2 mid-section.Last edited by bigshrimpin; 09-29-2005 at 10:02 PM.
10-01-2005, 06:19 PM #5Screaming And Flying!
- Dec 2001
- 9,502
- 269
- 191
- 1975
Hey
Big Shrimp, the powerhead is the same bolt pattern. Thats good about Mercs. The exhaust ports should be the same, and if they are not don't worry about it till you blow somthing and want to change that issue.
10-01-2005, 08:52 PM #6
should bolt up fine, but i would use your 2.4 exhaust piece and tunner
roy93 xr 2001 drag with a 15" drag
92 xb 2002 comp with a 15" drag
R.I.P. Phil "rpm racing" Watch over the rest of us my friend.
10-02-2005, 05:11 PM #7Screaming And Flying!
- Dec 2001
- 9,502
- 269
- 191
- 1975
Xr 2 150
I don't Know what year that is but the newer motors have different adaptors if they have the bucket cowl with brackets to hold the cowl. The early ones can interchange but the later ones have different gasket style so be aware of the changes.
10-03-2005, 08:43 AM #87000 RPM
- Feb 2005
- seattle
- 2,654
- 17
- 33
the exhaust ports are the same [mostly] but the tuning sections can be different. suggest you chang that as well. [ its the next section down from the exhaust plate.]
10-03-2005, 09:00 AM #9
Stoney did you by any chance live in St. Pete back in the 80's. With a giant ass rabbit ?
Bob
STV MOD VP
2.5 EFI
THROTTLE FLAT TO THE FLOOR TILL YOU SEE GOD....THEN LIFT
10-03-2005, 10:22 AM #105000 RPM
- Jun 2004
- florida
- 353
Damn!
You can't talk about his wife like that! Or...was she a Playboy bunny? LOL
10-03-2005, 03:51 PM #11
You guys crack me up!
I did live in St pete in 89 and then largo till 99 but didn't have a
GIANT ASS RABBIT! Or a playboy bunny!
Stoney
10-05-2005, 03:41 PM #125000 RPM
- Aug 2003
- Onset, MA
- 347
- 7
Thanks for the responses . . . Just picked up the motor for free!!!!
10-05-2005, 05:45 PM #13Screaming And Flying!
- Dec 2001
- 9,502
- 269
- 191
- 1975
If its free its for me...
You can't go wrong at that price.
