Results 16 to 30 of 63
Thread: turbocharging a stock 301
08-31-2005, 11:04 AM #16
08-31-2005, 10:38 PM #17
I dunno bout the mounts, but you can modify pontiac mounts for a chev, so I don't see why you couldn't go the other way. Do you know off hand what tranny you have?
89' Hydrostream Vista 200XP
Delta 3cyl FORCE
09-01-2005, 05:24 AM #18
Chevy will work
But 400 would be great if you can still find one. A lot of the pontiacs and buicks used a dual pattern bellhousing on the trans that would bolt to either. As for mounts, several holes are in the cradle frame to place mounts for several engine combos...V6, Chev, pont. So basically, just about anything is possible if you want to, it just depends on how "drop right in" you want to get.
09-01-2005, 09:14 AM #19
09-01-2005, 09:15 AM #20
ehhh just buy a turd gen wit a 305
09-01-2005, 09:17 AM #21
If you have a 4speed with od then you either have a 200-4R or a 700-R4. If you have a 3speed with a lock up converter its a TH350 with lock up converter. Hope this helps
09-01-2005, 09:17 AM #22
09-01-2005, 09:19 AM #23
09-01-2005, 09:23 AM #24
09-01-2005, 09:25 AM #25
Go for a ride, start from a stop and count the shifts. A lockup converter is a converter that locks and gives you a overdrive.
09-01-2005, 09:34 AM #26
dad wont let me drive it since he found out it has no back brakes so once i get new shoes ill let ya know... i have been drivin the beast (88 toyota pickup 5spd) cause my priorities are screwd up { http://forums.screamandfly.com/forum...760#post735760 }
fix daily driver or break motor in lol...
thanks
kevin
09-01-2005, 09:34 AM #27
What year car is this?
09-01-2005, 09:35 AM #28
09-01-2005, 09:37 AM #29
Break boat in .......... Use Toyota to pull boat to ramp...... burn $3.XX a gallon gas
09-01-2005, 09:41 AM #30
329 9/10 a gallon... 375 on the water!
yea i just want to see if this thing is gonna stay together (firist rebuild)... or how long untill its not... if it will just blow up ill put it away for the winter! nah i wont, who am i kiddin ill put the 225 powerhead sittin on my back deck on it and burn 375 a gallon!
haha
kevin
