Results 1 to 6 of 6
Thread: Gelcoat
07-22-2005, 07:19 AM #1
Gelcoat
I am looking for a recommendation for a gelcoat refinisher in the NJ or LI area. Anybody know somebody? Thanks
08-08-2005, 02:15 PM #2Member
- May 2002
- Palm Harbor, FL
- 72
Whats wrong with your gel?
Originally Posted by seamate
I'm trying to get some of the MD/PA/DE/NJ folks from the Checkmate Website to meet up down at the beach in DE or MD sometime for some back bay boating fun, you interested?
Herb
1986 Checkmate Starliner
Dillsburg, PA
08-08-2005, 02:20 PM #36000 RPM
- Mar 2003
- 1,333
You may want to do a search on the post Stvhelm did (Helmut) about yellowing white gelcoat, if I remember correctly he used muratic acid and it brought the white gelcoat back like new...don't get it near aluminum (jackplate and trim)
08-08-2005, 02:29 PM #4
If you find you need repair, try Gelcoat Joe on LI. He's a member here.
08-08-2005, 03:09 PM #5Member
- May 2002
- Palm Harbor, FL
- 72
Originally Posted by beko21
I tried the acid thing and no change. I let it sit on the deck in a small area and no change. I saw some fumes but no effect on the gel My hull is yellowed pretty much the same all over (not really that yellow but enough to bother me and make others notice), deck, sides, transom, etc. I did some wetsanding with 600 wet paper to see if that would work where the old numbers were (very white under the old original numbers and under the old pinstripe I removed). It seemed to work the best but it took a lot of sanding to lighten the hull but still not as white as where the numbers were so I stopped for now.
I would have thought it was supose to be off white if I hadn't removed my numbers and the old original pinstripe
08-08-2005, 05:59 PM #6
I'm not sure if it's available to you guys but there is a product called Y 10 that desolves yellow stains from gelcoat, it's blue jelly like stuff that you brush over the stain and it just disappears then wash off the residue with a hose. It's made here in Ireland so it';s probably not available over there! If you're stuck let me know and I can sort you out.
Alan
