Results 1 to 13 of 13
Thread: what thrust washer to use?
07-21-2005, 09:28 PM #1
i just picked up a quicksilver chopper 28P. its an over the hub. i have an 86 merc 2.4 motor. is there a speacial washer to use? is trhere a spacer used on the outside? im running out of thread when i tighten it down.
i have the washer from my laserII on it now and i need about 7-8 mm more to make it tight. what to do?Boatless at the moment. Looking for a 24-25' V
07-22-2005, 06:34 AM #2
What's the part number on your prop? You're not missing the bronze aft piece, are you? Maybe your washer is worn out. How thick is it?
07-22-2005, 08:47 PM #3
im not by the prop now but i do not have any bronze aft piece. what do they look like? i maye have something that will work.
07-23-2005, 09:37 AM #4
This is an A5 big-ear without the bronze tab ring.
07-23-2005, 09:40 AM #5
This is the same prop with the bronze tab ring installed. It has a spline-cut inner diameter, it fits into the end of the hub, and meshes onto the propshaft spline. You can see where the hub spline and the bronze part come together.
Do NOT run an A5 without this piece.'89 Hydrostream Vegas XT, '90 Merc 2.4 Bridgeport PCU EFI
07-24-2005, 02:24 PM #6
thanks pyro, i figured it would look something like that. do you think i could fnd one at a mercury dealer?
07-25-2005, 12:11 PM #7
Also, What Would Be The Harm in Running It With Out One? I Have A Spacer That Fits Tight On The Shaft. It Would be For Test Purposes Only. If The Prop Worked I Would Get The Proper Fiting.
08-03-2005, 02:55 PM #8
There would be no harm
I usually run my props with a standard washer on the end, and just make sure the nut is tightened to proper specs, maybe a touch more, because they now have a greater chance of loosening and back off the shaft. And your nice prop now is at the bottom of the lake. I check my prop everytime I run it, and sometimes when running to make sure there is no play between the prop and nut. Soon as it gets loose it does not take a whole lot of holeshots to keep it losening and the nut falling off. Spacing the prop on the back with another thrust washer is also not a bad thing to do, so your prop is running farthur at the end, but it all depends on what boat and prop combo your running. Make sure there is at least 1 turn on the nut and you can see some threads out the end of the nut.
Trey
08-17-2005, 06:52 AM #9
Hey Matt, did you get to try this yet? Could you turn it?
Chris Lacey <'((><
22' Redline SOB
Merc 225 3.0l
1995 Harley Davidson Road King
03-18-2006, 06:23 PM #10
Does anyone have a part number for this? Where can I get a couple?
Originally Posted by pyro*Got my Laser at the Bayou
*Is there any water in Michigan?
03-20-2006, 09:05 AM #11
What about if you wanted to drill one out for OMC? Do you still need the bronze piece?
Walking a fine line, and enjoying the view
03-20-2006, 12:48 PM #12
i ended up selling the prop and purchased one with the bronze tab ring already installed.
hey laredo, i have a thred in the prop sale are asking about these tab rings. there was a guy who said he has a couple. this was last month.Last edited by illMATTic; 03-20-2006 at 12:50 PM.
03-20-2006, 01:07 PM #13
The bad news is: I have several of those inserts in my tool box, along with the tabbed washer and nyloc nuts. I just never thought to send it with. by the time I sent this prop, I had been running OMC for a few years and forgot that there was another piece.
Chris Lacey <'((><
22' Redline SOB
Merc 225 3.0l
