Results 1 to 12 of 12
Thread: Trailer Dolly
04-18-2005, 03:02 PM #1
Trailer Dolly
Anybody made a powered device, either gas or electric, for moving their trailer around? It is all I can do to manually pull mine from the back garage to the front of the house to hook it up. I know some use riding lawnmowers but I was thinking more along a stand alone unit. I know they make commercial electric units. Interested in making my own and wanted ideas on what to utilize for drive train etc. I am sure somebody out there has made one of these. Thanks, Joey
04-18-2005, 03:08 PM #2Screaming And Flying!
- Oct 2003
- Cobourg, ON
- 7,194
I used to have a boat winch for my marine railway made out of an old snowblower. It would have pulled a trailer easily. An old rototiller would work well too.
04-18-2005, 08:01 PM #35000 RPM
- Mar 2003
- Miami, Fl
- 315
I have a little electric one at the shop it makes 500 ftlbs of torque ! Ill try to remember to take pictures. Only problem is if it gets in wet grass or not enough toung weight it spins the tire.
04-18-2005, 08:06 PM #4
04-20-2005, 08:14 AM #5
I would be curious how well a lightweight version would work tugging a trailer with less than 100# of toungue weight and 1000# of gross weight. Seems to me that it would slip too much unless you were moving it around a flat garage area.
Jason
Outboard Junkie
04-20-2005, 09:19 AM #66000 RPM
- Oct 2002
- Dallas
- 1,520
Jamoore....mechanical trialer dolly???? Are you talking about that boat in your Avitar?????
Don't know your situation so I won't make a joke....how about a manual trailer dolly?
Like this one...http://www.greatoutdoors.com/trailer...ilerdolly.html
04-20-2005, 09:22 AM #76000 RPM
- Florida
- 1,881
A golf cart works great if you have room for it.
Jim
04-20-2005, 05:43 PM #8
Fantastic Idea !
I see a lot of people laughing but this a true marketable product with the proper planning and outsourcing you could make this fly . I personnally have three trailers that are heavy and with a small powered device could be easily manuevered from their out of the way location . What comes to mind right awaY is a small industrial engine with tremendous reduction to keep power up and movement slow . Also has to be reversible easily and have a kill system . You have ignited a spark !!! Tom .
04-20-2005, 10:56 PM #9
I think for the amount of use that they would get, and the little amount of time they would run versus time sitting that the electric ones I linked to would be better than a gas powered one, there would be very little maintenance with the electric ones. I have seen larger versions that are electric and rechargeable, the batteries add weight so they work much better with light tongue weights and slippery surfaces.
Caleb
04-21-2005, 05:09 AM #10
i've seen them at the boat shows,
Time Warps suggestions look like the ones i've seen, so somebody is already doin it, not to say a master fabricator and brilliant engineering mind like professor Foley couldn't do one better, thats why they call it a Boing 747 instead of a Wright 747, or a Lightening 21 instead of a Skater,,, no wait what was i thinkin fun out
most overnite successes usually take at least 10 years
Certified turd polisher,
04-22-2005, 12:09 PM #11
Thanks for the discussion. Sorry I didn't see the responses sooner. I didn't get the notices that I had a reply and been busy.
Reese, yes it is for the boat pictured, no offense taken. I do have a manual dolly. I know the boat doesn't weigh much but it is all I can do to move it by myself and I am no slouch! It has to come across grass and it has just enough incline to make it a real task. I can't back through the gate due to tight quarters so I have to pull it out to hook it up.
I like the looks of the electric ones, just not the price. They don't look all that difficult to build. I was hoping someone had built their own and had some thoughts on what to use for the engine/motor and drive components. Any thoughts on where one would get an electric motor that had the torque/gearing for this?
Joey
04-23-2005, 04:21 AM #12
Check out Mc Master -Carr an industrial supplier , I will get their number for you . I can easily see several hundred for bits and pieces without labor to put one of these little puppies together , but sure would save our backs a lot of grief ! Tom .
