Results 1 to 6 of 6
    Aug 2004
    kingdom of bahrain
    meg welding mahcine..??
    AM I ASKING IN THE RIGHT PLACE??
    RIGHT NOW I AM USING A WELDING ROD'S 4MM AND OVER
    AND WANT TO IMPOVE MYSELF BY SKIPPING TO MEG WELDING
    SO COULD YOU PLEASE GIVE ME MORE IDEA ABOUT THIS MACHINE
    MY OLD MACHINE IS HOBART-USA
    GA
    its not always the gun its the man behind the trigger
    Dallas, TX
    what material are you welding? steel? aluminum?
    Miller and Lincon both make good machines. Their light duty stuff is pretty durable for use at home.
    Dec 2001
    Sunbury, Pa
    Hobart also makes a nice unit for home use
    Ralph Musser
    27' Fountain Fever W/ 525SC
    22' Rapid Craft W/ Evinrude 300 V8 January 2009 BOAT OF THE MONTH SOLD
    24' Triton 240 Gold W/ Mercury 60
    14' Royalcraft W/ Evinrude 75 father/daughter project
    Nov 2004
    BAYVILLE N.J.
    Mig Welding
    it is called a MIG welder, what thickness metal are you welding? you can get away with a 115W suitcase welder. that will weld uptoo 3/16in steel. if you are going to do alluminum then go for a tig welder, or you will have to get a larger 220W welder with a spool gun
    Feb 2006
    vancouver bc canada
    if you are interested in wire feed welding
    my best sujestion to you is to take a small welding cource at your local comunity coledge
    wire feed or MIG welding has advantages and disadvantages over conventional stick welding
    aluminum is a metal all to its own and needs spetial teckniques to work properly, it can be welded by MIG or TIG
    Jul 2008
    Port Angeles, WA
    You may have limited success teaching youself stick welding on steel, but I will just about gurantee you that you will be lost welding on aluminum with a wire feed machine, and REALLY lost doing TIG work on aluminum without some competent instruction. Do take a course at the local junior college, get some decent equipment if you are going to be serious, (the cheap stuff is just that..) and then you can charge your buddies to put together clean attractive and safe welds for them.
