Results 1 to 15 of 23
Thread: New Yammy
01-25-2005, 10:31 PM #1Junior Member
- Jan 2005
- 15
New Yammy
Can anyone give me pro and cons of the new VZ200 by Yamaha?
01-26-2005, 07:27 AM #27000 RPM
- Sep 2002
- Lakeland,Fla
- 2,500
If you are not resriticted by horsepower it is the same weight as the VZ250 and VZ300. It became a 3.3ltr this year and is quite a bit stronger than the 2.6ltr version
Fellow G-Man of the Sunshine Syndicate-Dixie Wrecked Chaptor..
We Put The F. U. in FUN
94 17MA Maverick 115 Yamaha
2006 Mustang GT, with a belt driven air cleaner
01-26-2005, 04:06 PM #3
lots of torque but may not be ideal for light hulls as vector said it is the weight of the 300 so lb for lb the 300 is a better option unless limited in power you can use... also due to it being big block more HP potential.. not sure if porting is different or if any hard parts have changed but a 250 or 300 ECM should wake it up if you need to keep the 200 SN and cowl...
01-26-2005, 08:42 PM #4Junior Member
- Jan 2005
- 15
Yes ,I am restricted.200max
Originally Posted by VectorPat
01-26-2005, 08:43 PM #5Junior Member
- Jan 2005
- 15
Thanks for the info
01-27-2005, 01:31 AM #6
Are you Inspected???? I have seen people swap ECM's in HP restricted instances and didnt get DQ'd B/c they were able to said it was replaced under warranty. maybe that could be something you could do????
However If they regularly inspect even that may be risky...
just an idea
01-27-2005, 07:07 PM #7Junior Member
- Jan 2005
- 15
Is there a motor out there with same power and less weight?
By the way, how much heavier is it than its predisseser?(don't know if spelled right)
Originally Posted by npartin
01-28-2005, 04:18 AM #8
Same power, less weight
Check out the Mercury Optimax 200XS. I don't remember the weight, but it ought to be lighter.
Or a traditional carburated or EFI engine for that sake. But hurry if you want a new engine.Markus' Performance Boating Links:
01-28-2005, 09:10 AM #95000 RPM
- Sep 2003
- Kansas
- 392
What are you running?
IMO if you are running a heavier hull or heavy loads the big block 200's (3.0L, 3.3L) would be a better choice; more torque. If you have a light hull than the higher winding 200xs (2.5L) would be
Allison XB2002 Comp Pro / 2.6L Yamaha 200 VMAX TRP
01-29-2005, 09:07 PM #10Junior Member
- Jan 2005
- 15
thanks
Does Yah have a motor comparable to 200xs in that reguard
Originally Posted by DarthVMAX
01-29-2005, 09:56 PM #11
not really as yahama advertises all of their 2 strokes at 4500-5500 rpm.....the 2.6 Oxx66 can be built to run with the XS as far as RPM range but that may not be allowed if your limited in HP...
01-29-2005, 10:09 PM #12Junior Member
- Jan 2005
- 15
I was trying to get away from the weight of the new 200VZ
100 lbs more than the XS.
I'm limited at 200 hp and also am putting it on 20 ' tin.
Looking for power at bothends and longevity(not planning on selling right away,15yr.
Originally Posted by npartinLast edited by cgp; 01-30-2005 at 10:52 AM.
01-30-2005, 11:02 AM #13
if you dont mind my asking what is the reason you are limited?? is it for tournaments, or is that all the boat is rated for??? because i f it is the boats rating i would do the 200 Hpdi with a 300 ECM but if it tournaments I would go with the XS
01-30-2005, 12:36 PM #14Junior Member
- Jan 2005
- 15
The rating is 200. (G3 HP200 DC).
Which 200 are you talking about Nick?
And please explain 300ECM and which xs.
I'm a dummy
01-30-2005, 12:52 PM #15Team Member
- Lake Coochiching, Ontario
- 7,705
- 269
- 472
- 1541
- 6 Post(s)
re: DI 200's
For a heavy boat the 3.3L 200's would be my choice
For a lighter boat like my Allison I'd go for the Mercury 200XS
200XS 2.5L 6000-6500 rpm 1.87 gears, 434 lb
Rude 200 HO 3.3L 5500-6000 rpm 1.86 gears, 517 lb
Yamaha 2.6L HPDI VMax 200 2.6L 4500-5500, 1.86 gears, 475 lb
Yamaha 3.3L HPDI VZ200 3.3L, 4500-5500, 1.81 gears, 529 lb
all but the VZ200 data from manufacturer claims
VZ200 from Feb Bass & Walleye boat
They turned their test engine to 5800 rpm
B&W state that the added displacement plus a new lower unit = 3-4 more mph
Only the 200XS requires premium fuel.
Plan B = 200 Carb motors = Merc only choice
Merc 200 2.5L, 5000-5600 rpm, 1.87 gears, 406 lb
Some time this year B&W are doing a 200 comparison test.
